[GRASS-stats] Problems installing spgrass6
Markus Neteler neteler at osgeo.org
Thu Oct 30 16:45:42 EDT 2008
Hi Edward,
On Thu, Oct 30, 2008 at 9:41 PM, Edward Tomlinson <e.j.tommo at gmail.com> wrote:
> Hi Markus,
> Thank you for your reply.
> I am using R version 2.7.2svn.
> Error in fun(...):
>     GDAL Error 1: libgrass_I.so cannot open shared object file: No such file
> or directory
Easy to fix:
- become "root" user
- create /etc/ld.so.conf.d/grass.conf
- content: path to GRASS libraries
- save and run
   ldconfig
- exit from "root"
then it should work.
Markus
More information about the grass-stats mailing list
