[GRASS-stats] Problems installing spgrass6
    Edward Tomlinson
    e.j.tommo at gmail.com
    Thu Oct 30 23:00:38 EDT 2008
Hi Markus,
Thank you very much. That worked fine!
Cheers,
Ed
2008/10/31 Markus Neteler <neteler at osgeo.org>
> Hi Edward,
> On Thu, Oct 30, 2008 at 9:41 PM, Edward Tomlinson <e.j.tommo at gmail.com>
> wrote:
> > Hi Markus,
> > Thank you for your reply.
> > I am using R version 2.7.2svn.
> > Error in fun(...):
> >     GDAL Error 1: libgrass_I.so cannot open shared object file: No such
> file
> > or directory
> Easy to fix:
> - become "root" user
> - create /etc/ld.so.conf.d/grass.conf
> - content: path to GRASS libraries
> - save and run
>   ldconfig
> - exit from "root"
> then it should work.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20081031/0d488299/attachment.html
More information about the grass-stats
