[GRASS-stats] GRASS/R interface
    Agustin Lobo
    Agustin.Lobo at ija.csic.es
    Fri Feb 13 04:47:07 EST 2009
Thanks, where?
Also, there is no way the grass environment could be passed
to spgrass6 if R had been started from a not-grass terminal?
This would circumvent a current problem in the
windows osgeo4w QGIS-GRASS-R environment.
Agus
2009/2/12 Markus Neteler <neteler at osgeo.org>:
> On Wed, Feb 11, 2009 at 8:25 AM, Agustin Lobo <aloboaleu at gmail.com> wrote:
>> In relation to current problems with spgrass6() in a
>> windows osgeo4w QGIS-GRASS-R environment,
>> I'd like to make sure that using spgrass6()
>> actually requires having launched R from within a
>> GRASS terminal, otherwise the user gets the
>> "GRASS not running" error message. Am I wrong? This is an important
>> step in practice that is not mentioned in the documents
>> that you are refering to.
> Now mentioned!
> best
> Markus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
e-mail Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
More information about the grass-stats
