[GRASS-stats] GRASS/R interface
Roger Bivand
Roger.Bivand at nhh.no
Fri Feb 13 05:00:07 EST 2009
On Fri, 13 Feb 2009, Agustin Lobo wrote:
> Thanks, where?
> Also, there is no way the grass environment could be passed
> to spgrass6 if R had been started from a not-grass terminal?
> This would circumvent a current problem in the
> windows osgeo4w QGIS-GRASS-R environment.
I'm still unsure of the steps you are taking. Are you opening a GRASS
location/mapset - for example from GRASS tools under Plugins ->, then from
the tools choosing the console, and entering the command to start R there?
Could you put a sequence of screenshots describing your process on a site
somewhere - I have no problem with regular QGIS 0.11.0. Starting spgrass6
outside the GRASS environment will most likely not work well at all,
because nothing that it needs to run is available (progam PATH, data
location, etc.).
Roger
> Agus
> 2009/2/12 Markus Neteler <neteler at osgeo.org>:
>> On Wed, Feb 11, 2009 at 8:25 AM, Agustin Lobo <aloboaleu at gmail.com> wrote:
>>> In relation to current problems with spgrass6() in a
>>> windows osgeo4w QGIS-GRASS-R environment,
>>> I'd like to make sure that using spgrass6()
>>> actually requires having launched R from within a
>>> GRASS terminal, otherwise the user gets the
>>> "GRASS not running" error message. Am I wrong? This is an important
>>> step in practice that is not mentioned in the documents
>>> that you are refering to.
>> Now mentioned!
>> best
>> Markus
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
