[GRASS-stats] Re: [GRASS-user] error: Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations.
Roger Bivand Roger.Bivand at nhh.no
Wed Jul 29 04:12:19 EDT 2009
On Wed, 29 Jul 2009, Nikos Alexandris wrote:
> stephen sefick wrote:
>> What computer architecture, operating system, what R version etc.?
> Right, I assume that people know that I am using Ubuntu Jaunty 64-bit, R
> 2.9.1, latest rpy2, grass-6.4.0svn from source.
Please always repeat everything every time; don't delete content from
threads.
I'm travelling and cannot handhold.
Build only from source, only one piece at a time, and check everything
every time. I'm sure that other people have seen dependency problems when
installing from binary on this platform. This is not seen on any other
platform (Linux, Windows, OSX). There are two underlying problems:
"dependency hell" and your inability to sort out your own system. I
suspect that the XML package in R does not have its dependencies
satisfied. It could also be GDAL/GRASS not having dependencies satisfied.
The reason to build from source is that then you control the dependencies,
rather than the reverse.
Please stop creating the impressionn that software that works for
effectively everyone else is broken only because you can't get your own
system to work, and expect others to do your work for you!
Roger
>> What is the error message?
> The message is the title of this thread.
>> I am usingce 6.4RC5 GRASS and R 2.9.1 on mac
>> OS X 10.5.7, and it is working fine. I remember there being a problem
>> with something, but I don't remember exactly what.  If you were to
>> provide the error message then maybe it would jog my memory.
> Sorry, that's all the prog prints.
>> Also, it may be a good idea to search the R-sig-geo list archive, as your
>> problem may have already been solved (assuming it is the same one that
>> I had).
> Before doing countless compilations/installations I filtered the web for
> an hour! I've found some similar messages in grass-dev's mailing-list
> but nothing specific.
> I thought that /etc/ld.so.conf is my problem... and I commented out all
> grass-versions but grass-6.4.0svn. I even removed all other
> grass-versions, (re-)installed X-times spgrass6 but no luck.
> It's the first time I see this message. I also tried to do some
> debugging but R requires, I guess, special treatment (meaning other than
> gdb, etc.) !?
> Nikos
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
