[GRASS-stats] Re: error: Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations.
Jarek Jasiewicz jarekj at amu.edu.pl
Thu Jul 30 01:56:47 EDT 2009
Nikos Alexandris pisze:
> On Wed, 2009-07-29 at 03:39 +0200, Nikos Alexandris wrote:
>> Hi dev's and advanced useRs,
>> I have seen this message for the X-th time now :-( while trying to load
>> (anything) data using readRAST6 or readVECT6.
>> I've rebuild grass-6.4.0svn 2-3 times now. I've re-installed R 2-3 times
>> as well. Not to mention how many attempts to get "spgrass6".
>> Which is the "incompatible library" and to which "module" does it refer
>> to? Is this an R error or a grass error? Any help is *higly*
>> appreciated.
> After so many posts of mine one more wont hurt :-p. Finally it was
> gdal-grass (however I want to mention that I got rid of all other
> grass-versions but 6.4.0sv).
> Thanks, Nikos
it was mentioned and solved eriler
http://lists.osgeo.org/pipermail/grass-stats/2009-January/000897.html
Jarek
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
More information about the grass-stats mailing list
