R: [GRASS-stats] r.reclass by rules
Agustin Lobo
alobolistas at gmail.com
Tue Sep 15 06:13:02 EDT 2009
Thanks, this is saving time, as I was having
to use r.mapcalc after r.reclass.
Is this important trick in the manual?
I could not find it. Perhaps I should have figured it out
after the example * = NULL, but I think
that should be specifically mentioned.
Agus
Aldo Clerici wrote:
> Agus,
> It should be:
> 1 4 6 = 100
> end
> Greetings
> A.Clerici
> -----Messaggio originale-----
> Da: grass-stats-bounces at lists.osgeo.org
> [mailto:grass-stats-bounces at lists.osgeo.org] Per conto di Agustin Lobo
> Inviato: mercoledì 9 settembre 2009 14.53
> A: grass-stats at lists.osgeo.org
> Oggetto: [GRASS-stats] r.reclass by rules
> Is r.reclass leaving as null any original
> value for which there is no reclassification rule?
> I mean, if A had a range 1 to 10 and we reclassify
> values 1, 4 and 6 to 100, are the rest
> of values changed to null? No way of
> leaving them unchanged?
> Thanks
> Agus
More information about the grass-stats
