R: [GRASS-stats] r.reclass by rules
Hamish hamish_b at yahoo.com
Sat Sep 19 11:23:34 EDT 2009
Agustin wrote:
> Thanks, this is saving time, as I was having
> to use r.mapcalc after r.reclass.
> Is this important trick in the manual?
> I could not find it. Perhaps I should have figured it out
> after the example * = NULL, but I think
> that should be specifically mentioned.
thanks for mentioning it was missing. The r.reclass manual is now updated
in SVN to point out this trick.
Helena: some kind soul has added a fail-safe into g.remove, now if you try
to remove a raster which has a reclass based upon it you get an error
message:
GRASS65> g.remove landuse.copy
WARNING: [landuse.copy at user1] is a base map. Remove reclassed map first:
         landuse.copy.reclass at user1
I'm assuming the g.remove -f force flag is there to override that.
Not sure if it notices that there is a reclass based upon it existing
in another mapset (perhaps owned by another user), but I guess you
make reclass maps based on other people's maps at your own risk. ie you
would naturally get mad at them, not the GIS, when they remove it.
Hamish
More information about the grass-stats mailing list
