[GRASS-stats] Re: spgrass and double precision data??
Roger Bivand Roger.Bivand at nhh.no
Mon Aug 30 12:16:57 EDT 2010
On Mon, 30 Aug 2010, Jarek Jasiewicz wrote:
> Hi.
> It may be solved problem because I use little older R version and spgrass,
> R version 2.10.0 (2009-10-26), spgrass 0.6-11:
This was fixed in spgrass 0.6-16.
Roger
> but if not, the problem seems to be clear:
> r=readRAST6("elevation.10m", plugin=FALSE)
> WARNING: Precision loss: Float32 can not preserve the DCELL precision of
>        raster <elevation.10m>. This can be avoided by using Float64
> ERROR: Raster export aborted.
> CPL ERROR 4:
> `/home/jarekj/grassdata/spearfish60/horton/.tmp/jarekj/elevation.10m' does
> not exist in the file system,
> and is not recognised as a supported dataset name.
> Error in .local(.Object, ...) :
> it seems spgrass do not like DCELL maps
> Jarek
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
