[GRASS-stats] Re: spgrass and double precision data??
Jarek Jasiewicz jarekj at amu.edu.pl
Mon Aug 30 12:51:55 EDT 2010
Roger Bivand pisze:
> On Mon, 30 Aug 2010, Jarek Jasiewicz wrote:
>> Hi.
>> It may be solved problem because I use little older R version and
>> spgrass,
>> R version 2.10.0 (2009-10-26), spgrass 0.6-11:
> This was fixed in spgrass 0.6-16.
> Roger
>> but if not, the problem seems to be clear:
>> r=readRAST6("elevation.10m", plugin=FALSE)
>> WARNING: Precision loss: Float32 can not preserve the DCELL precision of
>>        raster <elevation.10m>. This can be avoided by using Float64
>> ERROR: Raster export aborted.
>> CPL ERROR 4:
>> `/home/jarekj/grassdata/spearfish60/horton/.tmp/jarekj/elevation.10m'
>> does not exist in the file system,
>> and is not recognised as a supported dataset name.
>> Error in .local(.Object, ...) :
>> it seems spgrass do not like DCELL maps
>> Jarek
thanks
J.
More information about the grass-stats mailing list
