[GRASS-stats] administration rights: unable to use the flag
	"overwrite" with spgrass6
    Alexandre Villers
    villers.alexandre at gmail.com
    Tue Mar 20 06:47:47 EDT 2012
Good afternoon,
Sorry, I forgot to mention that I was using GRASS 6.4.1 on Windows 7,
not GRASS 7...
Best regards
Alex
On 19/03/2012 17:26, Roger Bivand wrote:
> On Mon, 19 Mar 2012, Alexandre Villers wrote:
>> Dear list,
>> I am unable to use the "overwrite" flag (e.g. with v.in.ogr) when
>> working from within R with spgrass6 on a windows 7 x64bits machine
>> (v.in.ogr.exe is not allowed to delete the file). It is apparently an
>> administrator rights issue as it works fine when I specifiy gisDbase
>> using a folder on my external hard disk. The problem is that I am the
>> administrator on this computer... and that I wouldn't expect any
>> error as the tempdir() function creates folder in my personal folder
>> in Users where I should have the rights anyway.
> I've now tried to install two GRASS 7 Windows binaries (19/3 and
> 12/3), and both are broken (no g.region.exe). If you can show me where
> a working GRASS 7 Windows binary can be found, I may look at this.
> Roger
>> Has anyone experienced such issue with windows 7 ?
>> Thanks in advance.
>> Alex
>> R version 2.14.2 (2012-02-29)
>> Platform: x86_64-pc-mingw32/x64 (64-bit)
>> locale:
>> [1] LC_COLLATE=English_United Kingdom.1252  LC_CTYPE=English_United
>> Kingdom.1252    LC_MONETARY=English_United Kingdom.1252 LC_NUMERIC=C
>> [5] LC_TIME=English_United Kingdom.1252
>> attached base packages:
>> [1] stats     graphics  grDevices utils     datasets  methods   base
>> other attached packages:
>> [1] spgrass6_0.7-9 XML_3.9-4.1    sp_0.9-97
>> loaded via a namespace (and not attached):
>> [1] grid_2.14.2    lattice_0.20-0
>> grass-stats mailing list
>> grass-stats at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
More information about the grass-stats
