[GRASS-stats] administration rights: unable to use the flag
	"overwrite" with spgrass6
    Roger Bivand
    Roger.Bivand at nhh.no
    Mon Mar 19 11:40:48 EDT 2012
On Mon, 19 Mar 2012, Roger Bivand wrote:
> On Mon, 19 Mar 2012, Alexandre Villers wrote:
>> Dear list,
>> I am unable to use the "overwrite" flag (e.g. with v.in.ogr) when working
>> from within R with spgrass6 on a windows 7 x64bits machine (v.in.ogr.exe is
>> not allowed to delete the file). It is apparently an administrator rights
>> issue as it works fine when I specifiy gisDbase using a folder on my
>> external hard disk. The problem is that I am the administrator on this
>> computer... and that I wouldn't expect any error as the tempdir() function
>> creates folder in my personal folder in Users where I should have the
>> rights anyway.
> I've now tried to install two GRASS 7 Windows binaries (19/3 and 12/3), and
> both are broken (no g.region.exe). If you can show me where a working GRASS 7
> Windows binary can be found, I may look at this.
>From the error logs on Martin's site, the binary has been badly broken
from 11 March, with a long error log. 10 March looks more or less OK.
Roger
> Roger
>> Has anyone experienced such issue with windows 7 ?
>> Thanks in advance.
>> Alex
>> R version 2.14.2 (2012-02-29)
>> Platform: x86_64-pc-mingw32/x64 (64-bit)
>> locale:
>> [1] LC_COLLATE=English_United Kingdom.1252  LC_CTYPE=English_United
>> Kingdom.1252    LC_MONETARY=English_United Kingdom.1252 LC_NUMERIC=C
>> [5] LC_TIME=English_United Kingdom.1252
>> attached base packages:
>> [1] stats     graphics  grDevices utils     datasets  methods   base
>> other attached packages:
>> [1] spgrass6_0.7-9 XML_3.9-4.1    sp_0.9-97
>> loaded via a namespace (and not attached):
>> [1] grid_2.14.2    lattice_0.20-0
>> grass-stats mailing list
>> grass-stats at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Department of Economics, NHH Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
