[GRASS-stats] administration rights: unable to use the flag "overwrite" with spgrass6
Roger Bivand Roger.Bivand at nhh.no
Mon Mar 19 11:26:35 EDT 2012
On Mon, 19 Mar 2012, Alexandre Villers wrote:
> Dear list,
> I am unable to use the "overwrite" flag (e.g. with v.in.ogr) when working
> from within R with spgrass6 on a windows 7 x64bits machine (v.in.ogr.exe is
> not allowed to delete the file). It is apparently an administrator rights
> issue as it works fine when I specifiy gisDbase using a folder on my external
> hard disk. The problem is that I am the administrator on this computer... and
> that I wouldn't expect any error as the tempdir() function creates folder in
> my personal folder in Users where I should have the rights anyway.
I've now tried to install two GRASS 7 Windows binaries (19/3 and 12/3),
and both are broken (no g.region.exe). If you can show me where a working
GRASS 7 Windows binary can be found, I may look at this.
Roger
> Has anyone experienced such issue with windows 7 ?
> Thanks in advance.
> Alex
> R version 2.14.2 (2012-02-29)
> Platform: x86_64-pc-mingw32/x64 (64-bit)
> locale:
> [1] LC_COLLATE=English_United Kingdom.1252  LC_CTYPE=English_United
> Kingdom.1252    LC_MONETARY=English_United Kingdom.1252 LC_NUMERIC=C
> [5] LC_TIME=English_United Kingdom.1252
> attached base packages:
> [1] stats     graphics  grDevices utils     datasets  methods   base
> other attached packages:
> [1] spgrass6_0.7-9 XML_3.9-4.1    sp_0.9-97
> loaded via a namespace (and not attached):
> [1] grid_2.14.2    lattice_0.20-0
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Department of Economics, NHH Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
