[GRASS-stats] rgrass7_0.1-2 on CRAN
Roger Bivand
Roger.Bivand at nhh.no
Mon Aug 24 00:05:04 PDT 2015
I've just submitted a new version of rgrass7 to CRAN, and the source
package is now available. The Windows CRAN binary will follow shortly, but
the OSX CRAN Mavericks binary may be delayed. This is because the new
version suggests the most recent rgdal_1.0-6, which fixes an issue with
the SQLite driver in GDAL2, seen when that driver is available.
The main change is to move the vector interface to using the SQLite format
for intermediate files if it is available, and to get around the field
name length restriction when using the shapefile format. Users should not
see changes in behaviour, but I'd be grateful for reports to ensure that
using these alternative mechanisms does not change results. Among other
things, the laundering of SQLite field names is turned off, to prevent
unintended conversion to lower case.
Suggestions and reports welcome!
Roger
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
