[GRASS-stats] rgrass7_0.1-2 on CRAN
Rainer M Krug
Rainer at krugs.de
Mon Aug 24 01:24:33 PDT 2015
Roger Bivand <Roger.Bivand at nhh.no> writes:
> I've just submitted a new version of rgrass7 to CRAN, and the source
> package is now available. The Windows CRAN binary will follow shortly,
> but the OSX CRAN Mavericks binary may be delayed. This is because the
> new version suggests the most recent rgdal_1.0-6, which fixes an issue
> with the SQLite driver in GDAL2, seen when that driver is available.
> The main change is to move the vector interface to using the SQLite
> format for intermediate files if it is available, and to get around
> the field name length restriction when using the shapefile
> format.
Thanks Roger - this is a very welcome improvement.
Cheers,
Rainer
> Users should not see changes in behaviour, but I'd be grateful
> for reports to ensure that using these alternative mechanisms does not
> change results. Among other things, the laundering of SQLite field
> names is turned off, to prevent unintended conversion to lower case.
> Suggestions and reports welcome!
> Roger
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150824/6f459b75/attachment.pgp>
More information about the grass-stats
