[GRASS-stats] Some refactoring and fixing
Rainer M Krug
Rainer at krugs.de
Wed Jan 28 08:58:02 PST 2015
Hi Roger
it seems that there is something not as it should be with the builds of
spgrass6 and spgrass7 - there are at the moment GRASS, spgrass and
spgrass7 but no spgrass6 - I don't have much experience with r-forge,
could you please check what is going on?
Thanks,
Rainer
Rainer M Krug <r.m.krug at gmail.com> writes:
> Envoyé de mon iPhone
>> Le 28 janv. 2015 à 15:55, Thomas Adams <tea3rd at gmail.com> a écrit :
>> Rainer,
>> Where can I get the new spgrass6 and spgrass7 to do some testing?
> The repository is on https://r-forge.r-project.org/projects/spgrass/ .
> It doesn't seem to be build yet so you have to install it from the svn
> repo or wait a few hours - then you shoud be able to install it via
> R install command: install.packages("spgrass6", repos="http://R-Forge.R-project.org")
> Cheers,
> Rainer
>> Thank you,
>> Tom
>>> On Wed, Jan 28, 2015 at 7:23 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>>> Rainer M Krug <Rainer at krugs.de> writes:
>>> > Roger Bivand <Roger.Bivand-aX1nC9UfZf8 at public.gmane.org> writes:
>>> >> On Tue, 27 Jan 2015, Rainer M Krug wrote:
>>> >>> Hi
>>> >>> I just committed a few of commits which refactor the code of readRAST,
>>> >>> writeRAST, readVECT & writeVECT by creating internal fi=unctions for
>>> >>> reading / writing for plugin / non-plugin and moving the default values
>>> >>> (get...Options()) into the function definitions.
>>> >> Good, thanks; I've updated the default values in the help files. It's
>>> >> easy to check for discrepancies in spgrass/pkg:
>>> >> R CMD build spgrass7
>>> >> R CMD check spgrass7_0.1-0.tar.gz
>>> > Thanks - haven't thought about about the check - will do the next time.
>>> >> Maybe we could quieten the progress bar in the output from checking?
>>> >> As in:
>>> >> pkg/spgrass7.Rcheck/spgrass7.Rout
>>> >> (local file, not added to repository, created by R CMD check if run in
>>> >> spgrass/pkg).
>>> >>> Also, I added tryCatch blocks to close open connections and to reset
>>> >>> echoCmdOption. I ran the examples before each commit and I did not see
>>> >>> any errors or changed behavior.
>>> >>> Apologies for the typos in the commit messages - I only saw them later.
>>> >>> To stick with consistency, I would recommend to rename the package to
>>> >>> spgrass7 and to look into the possibility to create a meta-package which
>>> >>> uses spgrass6 or spgrass7 (I don't know about the GRASS 5 interface -
>>> >>> haven't used it) depending on the GRASS GIS version set / loaded.
>>> >> I've renamed spgrass as spgrass7 - when you update, the change will
>>> >> propagate.
>>> > Thanks - got it.
>>> >> I'm unsure about a metapackage, maybe block version 7 in
>>> >> spgrass6 (following the parameter and flag name harmonisation).
>>> > Yes - spgrass6 for 6.x, spgrass7 for 7.x.
>>> > Will respnd in more detail tomorrow.
>>> OK - I just committed a blocking mechanism which for spgrass6 and
>>> spgrass7 so that they
>>> a) when R is started in GRASS, the package can not be loaded if the
>>> versions are not compatible and
>>> b) initGRASS raises an error if the GRASS GIS version in gisBase is not
>>> compatible with the package version
>>> If you think this is the right approach, the help files still need to be
>>> amended to reflect this change.
>>> I was thinking if it would make sense to introduce an overwrite
>>> mechanism for these checks to enable "non-standard" use or testing?
>>> I haven't looked at references for GRASS 7.0 in spgrass6 yet.
>>> Cheers,
>>> Rainer
>>> > Thanks,
>>> > Rainer
>>> >> Best wishes,
>>> >> Roger
>>> >>> Cheers,
>>> >>> Rainer
>>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
>>> Centre of Excellence for Invasion Biology
>>> Stellenbosch University
>>> South Africa
>>> Tel : +33 - (0)9 53 10 27 44
>>> Cell: +33 - (0)6 85 62 59 98
>>> Fax : +33 - (0)9 58 10 27 44
>>> Fax (D): +49 - (0)3 21 21 25 22 44
>>> email: Rainer at krugs.de
>>> Skype: RMkrug
>>> PGP: 0x0F52F982
>>> grass-stats mailing list
>>> grass-stats at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-stats
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150128/d66399ff/attachment.pgp>
More information about the grass-stats
