[GRASS-stats] Some refactoring and fixing
Rainer M Krug
Rainer at krugs.de
Wed Jan 28 09:03:48 PST 2015
OK - the problem seems to be a name conflict. The build system status
report [1] states:
| - Package name conflicts:
| [7] "rspatial: spgrass6" "spgrass: spgrass6"
So the easiest to install at the moment seems to be to checkout the
sources via
| svn checkout svn://r-forge.r-project.org/svnroot/spgrass/
and then install from the sources.
Cheers,
Rainer
Rainer M Krug <Rainer at krugs.de> writes:
> Hi Roger
> it seems that there is something not as it should be with the builds of
> spgrass6 and spgrass7 - there are at the moment GRASS, spgrass and
> spgrass7 but no spgrass6 - I don't have much experience with r-forge,
> could you please check what is going on?
> Thanks,
> Rainer
> Rainer M Krug <r.m.krug at gmail.com> writes:
>> Envoyé de mon iPhone
>>> Le 28 janv. 2015 à 15:55, Thomas Adams <tea3rd at gmail.com> a écrit :
>>> Rainer,
>>> Where can I get the new spgrass6 and spgrass7 to do some testing?
>> The repository is on https://r-forge.r-project.org/projects/spgrass/ .
>> It doesn't seem to be build yet so you have to install it from the svn
>> repo or wait a few hours - then you shoud be able to install it via
>> R install command: install.packages("spgrass6", repos="http://R-Forge.R-project.org")
>> Cheers,
>> Rainer
>>> Thank you,
>>> Tom
>>>> On Wed, Jan 28, 2015 at 7:23 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>>>> > Roger Bivand <Roger.Bivand-aX1nC9UfZf8 at public.gmane.org> writes:
>>>> >> On Tue, 27 Jan 2015, Rainer M Krug wrote:
>>>> >>> Hi
>>>> >>> I just committed a few of commits which refactor the code of readRAST,
>>>> >>> writeRAST, readVECT & writeVECT by creating internal fi=unctions for
>>>> >>> reading / writing for plugin / non-plugin and moving the default values
>>>> >>> (get...Options()) into the function definitions.
>>>> >> Good, thanks; I've updated the default values in the help files. It's
>>>> >> easy to check for discrepancies in spgrass/pkg:
>>>> >> R CMD build spgrass7
>>>> >> R CMD check spgrass7_0.1-0.tar.gz
>>>> > Thanks - haven't thought about about the check - will do the next time.
>>>> >> Maybe we could quieten the progress bar in the output from checking?
>>>> >> As in:
>>>> >> pkg/spgrass7.Rcheck/spgrass7.Rout
>>>> >> (local file, not added to repository, created by R CMD check if run in
>>>> >> spgrass/pkg).
>>>> >>> Also, I added tryCatch blocks to close open connections and to reset
>>>> >>> echoCmdOption. I ran the examples before each commit and I did not see
>>>> >>> any errors or changed behavior.
>>>> >>> Apologies for the typos in the commit messages - I only saw them later.
>>>> >>> To stick with consistency, I would recommend to rename the package to
>>>> >>> spgrass7 and to look into the possibility to create a meta-package which
>>>> >>> uses spgrass6 or spgrass7 (I don't know about the GRASS 5 interface -
>>>> >>> haven't used it) depending on the GRASS GIS version set / loaded.
>>>> >> I've renamed spgrass as spgrass7 - when you update, the change will
>>>> >> propagate.
>>>> > Thanks - got it.
>>>> >> I'm unsure about a metapackage, maybe block version 7 in
>>>> >> spgrass6 (following the parameter and flag name harmonisation).
>>>> > Yes - spgrass6 for 6.x, spgrass7 for 7.x.
>>>> > Will respnd in more detail tomorrow.
>>>> OK - I just committed a blocking mechanism which for spgrass6 and
>>>> spgrass7 so that they
>>>> a) when R is started in GRASS, the package can not be loaded if the
>>>> versions are not compatible and
>>>> b) initGRASS raises an error if the GRASS GIS version in gisBase is not
>>>> compatible with the package version
>>>> If you think this is the right approach, the help files still need to be
>>>> amended to reflect this change.
>>>> I was thinking if it would make sense to introduce an overwrite
>>>> mechanism for these checks to enable "non-standard" use or testing?
>>>> I haven't looked at references for GRASS 7.0 in spgrass6 yet.
>>>> Cheers,
>>>> Rainer
>>>> > Thanks,
>>>> > Rainer
>>>> >> Best wishes,
>>>> >> Roger
>>>> >>> Cheers,
>>>> >>> Rainer
>>>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
>>>> Centre of Excellence for Invasion Biology
>>>> Stellenbosch University
>>>> South Africa
>>>> Tel : +33 - (0)9 53 10 27 44
>>>> Cell: +33 - (0)6 85 62 59 98
>>>> Fax : +33 - (0)9 58 10 27 44
>>>> Fax (D): +49 - (0)3 21 21 25 22 44
>>>> email: Rainer at krugs.de
>>>> Skype: RMkrug
>>>> PGP: 0x0F52F982
>>>> _______________________________________________
>>>> grass-stats mailing list
>>>> grass-stats at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-stats
Footnotes:
[1] http://download.r-forge.r-project.org/STATUS
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150128/dc47bbd9/attachment.pgp>
More information about the grass-stats
