[GRASS-stats] R interface to grass 7.1
    Rainer M Krug
    Rainer at krugs.de
    Fri Jun  5 00:51:31 PDT 2015
Roger Bivand <Roger.Bivand at nhh.no> writes:
>>> Hi,
>>> This is:
>>> http://trac.osgeo.org/grass/wiki/GSoC/2015#Neweasy-to-usecommandlineinterfaceforGRASSGIS
>>> is it? Did it get accepted - I don't see this on:
>>> http://www.google-melange.com/gsoc/org2/show/google/gsoc2015/osgeo
>>> and think that only improved metadata got funded.
>> This is true as far as I know, but it seems that Vaclac took it in
>> his own hands to code the initial stages and he checked it into the
>> GRASS 7.1 source.
>> I installed GRASS 7.1 from source using homebrew (the formula is in a
>> pending pull request) and I could execute the examples fine.
>>> Do we know what the actual status is on this?
>> The
>> | grass71 MAPSET --exec THE GRASS COMAND WITH WHATEVER COMES NOW
>> is working, but I don't know if it has been tested a lot. For testing,
>> the sp collection could help as there are already examples which one
>> could run.
>> Otherwise - no idea - but it seems to be going forward.
>>> I'd feel that this could be a variant in rgrass7 if it becomes
>>> available,
>> Yes - some changes and getting rid of the initialisation of the GRASS
>> session, and only provide the path to the grass71 executable.
>>> but I'm not sure how it would expose the interface description.
>> --8<---------------cut here---------------start------------->8---
>> grass71 --exec g.list --interface-description
>> --8<---------------cut here---------------end--------------->8---
>> I just tried it out.
>> or, maybe safer,
>> grass71 PATH/TO/MAPSET --exec g.list --interface-description
>> This is only the first stage, and Vaclac seems to be very much open to
>> suggestions and discussion on which direction this should go.
>> The discussion is on grass-user.
>> It seems that you are planning to move the sp packages to github - is
>> this true?
> Just on this, no, I will give up maintaining if anyone moves the main
> sp repository to git, and especially github, which is a proprietory
> corporation. Git is a bad choice going forward, as the important
> "responsibility" element is pulverised (good for projects with very
> strong brands, so someone will be responsible, probably bad for
> projects without strong brands with few active developers and lots of
> users sitting on their hands). Git is usable, and can be used like svn
> or similar centralised repositories, but is several steps backward
> IMO. It's got popular through github because projects avoid having to
> host their own repos. We'll see whether PROJ.4 falls apart after
> migration to github (it's very weak already). Github mostly attracts
> on coolness, which is often orthogonal to productive work.
I just thought that there was a discussion about this on the mailing
list, but I must have mixed them up (probably with PROJ.4 ?).
No need to change anything at the moment.
Cheers,
Rainer
> Roger
>> Cheers,
>> Rainer
>>> Best wishes,
>>> Roger
>>>> Hi
>>>> I guess you have seen the announcement from Vaclac Petras about the new
>>>> command line interface to R. This sounds very exciting and I would like
>>>> to start playing with the R-GRASS 7.1 interface. What would be the best
>>>> approach concerning git / svn? should I setup my own github for this or
>>>> should I slot in one of the spgrass repositories?
>>>> Thanks,
>>>> Rainer
>>>> http://permalink.gmane.org/gmane.comp.gis.grass.user/51680
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150605/6e0b1d5f/attachment.pgp>
More information about the grass-stats
