[GRASS-stats] R interface to grass 7.1
Rainer M Krug Rainer at krugs.de
Fri Jun 5 01:20:07 PDT 2015
Edzer Pebesma <edzer.pebesma at uni-muenster.de> writes:
> On 06/04/2015 09:44 PM, Roger Bivand wrote:
>> On Thu, 4 Jun 2015, Rainer M Krug wrote:
>>> Roger Bivand <Roger.Bivand at nhh.no> writes:
>>>> Hi,
>>>> This is:
>>>> http://trac.osgeo.org/grass/wiki/GSoC/2015#Neweasy-to-usecommandlineinterfaceforGRASSGIS
>>>> is it? Did it get accepted - I don't see this on:
>>>> http://www.google-melange.com/gsoc/org2/show/google/gsoc2015/osgeo
>>>> and think that only improved metadata got funded.
>>> This is true as far as I know, but it seems that Vaclac took it in
>>> his own hands to code the initial stages and he checked it into the
>>> GRASS 7.1 source.
>>> I installed GRASS 7.1 from source using homebrew (the formula is in a
>>> pending pull request) and I could execute the examples fine.
>>>> Do we know what the actual status is on this?
>>> The
>>> | grass71 MAPSET --exec THE GRASS COMAND WITH WHATEVER COMES NOW
>>> is working, but I don't know if it has been tested a lot. For testing,
>>> the sp collection could help as there are already examples which one
>>> could run.
>>> Otherwise - no idea - but it seems to be going forward.
>>>> I'd feel that this could be a variant in rgrass7 if it becomes
>>>> available,
>>> Yes - some changes and getting rid of the initialisation of the GRASS
>>> session, and only provide the path to the grass71 executable.
>>>> but I'm not sure how it would expose the interface description.
>>> --8<---------------cut here---------------start------------->8---
>>> grass71 --exec g.list --interface-description
>>> --8<---------------cut here---------------end--------------->8---
>>> I just tried it out.
>>> or, maybe safer,
>>> grass71 PATH/TO/MAPSET --exec g.list --interface-description
>>> This is only the first stage, and Vaclac seems to be very much open to
>>> suggestions and discussion on which direction this should go.
>>> The discussion is on grass-user.
>>> It seems that you are planning to move the sp packages to github - is
>>> this true?
>> Just on this, no, I will give up maintaining if anyone moves the main sp
>> repository to git, and especially github, which is a proprietory
>> corporation. Git is a bad choice going forward, as the important
>> "responsibility" element is pulverised (good for projects with very
>> strong brands, so someone will be responsible, probably bad for projects
>> without strong brands with few active developers and lots of users
>> sitting on their hands). Git is usable, and can be used like svn or
>> similar centralised repositories, but is several steps backward IMO.
>> It's got popular through github because projects avoid having to host
>> their own repos. We'll see whether PROJ.4 falls apart after migration to
>> github (it's very weak already). Github mostly attracts on coolness,
>> which is often orthogonal to productive work.
>> Roger
> I have less problems with github, and so sp might migrate one day. Right
> now, Roger and I do the majority of the work on sp, so svn on r-forge
> makes most sense. Contributors send patches, or code snippets in email.
I am fine with this.
> Once I see an easy way to use travis-ci for the full check on all of
> sp's reverse dependencies I will adopt that, at the cost of having to
> keep git and svn synced. Right now this check [*] takes me an absurd
> amount of time.
I just looked at travis-ci for the first time, and it looks really
interesting.
A mirror might be quite interesting in light of travis-ci - I just found
this on a quick google:
http://danielpocock.com/automatically-mirroring-svn-repositories-to-git-and-github
which *sounds* easy enough.
Cheers,
Rainer
> [*] I now use:
> library(sp)
> demo(depend)
>>> Cheers,
>>> Rainer
>>>> Best wishes,
>>>> Roger
>>>>> Hi
>>>>> I guess you have seen the announcement from Vaclac Petras about the new
>>>>> command line interface to R. This sounds very exciting and I would like
>>>>> to start playing with the R-GRASS 7.1 interface. What would be the best
>>>>> approach concerning git / svn? should I setup my own github for this or
>>>>> should I slot in one of the spgrass repositories?
>>>>> Thanks,
>>>>> Rainer
>>>>> http://permalink.gmane.org/gmane.comp.gis.grass.user/51680
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150605/b94fcf0e/attachment-0001.pgp>
More information about the grass-stats mailing list
