[GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames errors
Eduardo Diez
eduardodiez at gmx.com
Fri Oct 9 07:04:10 PDT 2015
Roger, with GRASS version 7.0.1 and rgrass7_0.1-3, readVECT now doesn't ask
for the driver to use but gives the same error as before:
writeVECT(SDF = mz.pol, vname = zm.pol, v.in.ogr_flags = "o")
Over-riding projection check
Check if OGR layer <q7468fb> contains polygons...
Importing 205 features (OGR layer <q7468fb>)...
Registering primitives...
3924 primitives registered
12866 vertices registered
Number of nodes: 2884
Number of primitives: 3924
Number of points: 0
Number of lines: 0
Number of boundaries: 3924
Number of centroids: 0
Number of areas: -
Number of isles: -
Cleaning polygons
Breaking polygons...
Breaking polygons (pass 1: select break points)...
Breaking polygons (pass 2: break at selected points)...
Removing duplicates...
Breaking boundaries...
Cleaning boundaries at nodes...
Merging boundaries...
Removing dangles...
Building areas...
205 areas built
13 isles built
Number of nodes: 2929
Number of primitives: 7268
Number of points: 0
Number of lines: 0
Number of boundaries: 7268
Number of areas: 205
Number of isles: 13
Removing bridges...
498 primitives registered
5828 vertices registered
Building areas...
205 areas built
13 isles built
Attaching islands...
Number of nodes: 306
Number of primitives: 498
Number of points: 0
Number of lines: 0
Number of boundaries: 498
Number of isles: 13
Finding centroids for OGR layer <q7468fb>...
Writing centroids...
205 input polygons
Total area: 1.25187E+006 (205 areas)
Copying features...
WARNING: Unable to delete file
'C:/Users/ediez1/AppData/Local/Temp/Rtmpqkeay4/file480c1e5e16a7/file480c11cc233b/.tmp/unknown/vector/tmp_8308/coor'
Building topology for vector map <q7468fb at file480c11cc233b>...
703 primitives registered
6033 vertices registered
Building areas...
205 areas built
13 isles built
Attaching centroids...
Number of primitives: 703
Number of points: 0
Number of lines: 0
Number of centroids: 205
Number of isles: 13
> execGRASS("v.clean", flags = c("overwrite"), input = zm.pol,
+ output = zm.gnrl, tool = "rmarea", threshold = 3000)
Tool: Threshold
Remove small areas: 3000
Copying features...
Rebuilding parts of topology...
Building topology for vector map <u10f44b at file480c11cc233b>...
Building areas...
205 areas built
13 isles built
Number of points: 0
Number of lines: 0
Number of isles: 13
Tool: Remove small areas
174 areas of total size 50601.7 removed
Rebuilding topology for output vector map...
333 primitives registered
4705 vertices registered
Building areas...
31 areas built
3 isles built
Number of nodes: 274
Number of primitives: 333
Number of points: 0
Number of lines: 0
Number of boundaries: 302
Number of centroids: 31
Number of areas: 31
Number of isles: 3
> zm.fnl <- readVECT(zm.gnrl)
Error in scan(file, what, nmax, sep, dec, quote, skip, nlines, na.strings,
line 4 did not have 2 elements
> sessionInfo()
R version 3.2.2 (2015-08-14)
Platform: x86_64-w64-mingw32/x64 (64-bit)
Running under: Windows 7 x64 (build 7601) Service Pack 1
locale:
[1] LC_COLLATE=English_United States.1252 LC_CTYPE=English_United
States.1252 LC_MONETARY=English_United States.1252
[4] LC_NUMERIC=C LC_TIME=English_United
States.1252
attached base packages:
[1] stats graphics grDevices utils datasets methods base
other attached packages:
[1] RPyGeo_0.9-3 RSAGA_0.94-3 plyr_1.8.3 gstat_1.0-26
shapefiles_0.7 foreign_0.8-65 maptools_0.8-37 rgdal_1.0-7
classInt_0.1-23
[10] raster_2.4-20 rgrass7_0.1-3 XML_3.98-1.3 sp_1.2-0
loaded via a namespace (and not attached):
[1] Rcpp_0.12.1 intervals_0.15.1 lattice_0.20-33 FNN_1.1
spacetime_1.1-4 class_7.3-13 zoo_1.7-12 grid_3.2.2
[9] e1071_1.6-7 xts_0.9-7 tools_3.2.2
Thanks
2015-10-08 18:57 GMT-03:00 Roger Bivand <Roger.Bivand at nhh.no>:
> Sorry this has taken a long time; please try installing the development
> version available from:
> http://win-builder.r-project.org/8Y3Ihj451Clx
> (rgrass7_0.1-3.zip). The problem was the use of "_" instead of " " in the
> name of the OGR shapefile driver - in OGR and R it is "ESRI Shapefile", in
> GRASS it is "ESRI_Shapefile". Because the new long-name work-around worked
> on systems not needing to use this driver, it wasn't properly tested - and
> on Windows the GRASS standalone has OGR with the SQLite driver, but the
> Windows rgdal binary does not have SQLite. You may wish to install the R
> RSQLite package to move data if you use long field/column names.
> Before installing this development version, and after library(rgrass7),
> run example(readVECT) in the basic nc location from:
> https://grass.osgeo.org/sampledata/north_carolina/nc_basic_spm_grass7.zip
> it should fail. Then restart R, install the development version of rgrass7
> from the first link, and repeat - it works for me and should resolve the
> problem.
> Hope this helps,
> Roger
> Roger Bivand
> Norwegian School of Economics
> Helleveien 30, 5045 Bergen, Norway
> Fra: grass-stats-bounces at lists.osgeo.org [
> grass-stats-bounces at lists.osgeo.org] på vegne av Eduardo Diez [
> eduardodiez at gmx.com]
> Sendt: 24. september 2015 9:11
> Til: grass-stats at lists.osgeo.org
> Emne: [GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames errors
> Hi, I'm a user of R mostly for spatial information processing. Besides sp,
> maptools, etc. i also use functions from GRASS, at first through spgrass6
> and then rgrass7. A few days ago, I started having trouble reading and
> writing SpatialPolygonsDataFrames using readVECT and writeVECT. I tried
> both reinstalling both grass (6.4.4, 7.0.0 and 7.0.1) and the R packages
> (spgrass6 0.8-6 and rgrass7 0.1-2), and also with different R objects but i
> kept getting the same errors.
> The "mult.r" object is a RasterLayer with 4 zones and the objective is to
> convert it to polygons and "clean" small areas with v.clean rmarea (as i
> don't currently know a way of doing this in plain R).
> The first thing that came out strange was that when executing writeVECT it
> would ask me for the driver to use (in the way of rgdal's writeOGR, it
> didn't ask for it before). I figured out that object to be written should
> be projected (not in lat-lon, don't know why). After doing this i could
> write the vector and execute v.clean. The problem came again when trying to
> read the cleaned polygons back to R.
> Below i paste an extract of my R console with the errors and some
> information.
> Thanks in advance,
> Eduardo
> > mult.rp <- projectRaster(mult.r, crs = prj.crs, method = "ngb")
> > mult.pol <- rasterToPolygons(mult.rp, dissolve = T)
> > initGRASS(gisBase = "c:/Program Files (x86)/GRASS GIS 7.0.1", home =
> tempdir(), override = T)
> gisdbase C:/Users/ediez1/AppData/Local/Temp/RtmpegbyiQ
> location file2f7c6dc070e6
> mapset file2f7c30eb3f52
> rows 1
> columns 1
> north 1
> south 0
> west 0
> east 1
> nsres 1
> ewres 1
> projection NA
> > writeVECT(mult.pol, "pol1", v.in.ogr_flags = "o")
> Error: !is.null(driver) is not TRUE
> > writeVECT(mult.pol, "pol1", v.in.ogr_flags = "o", driver = "ESRI
> Shapefile")
> Check if OGR layer <r848659> contains polygons...
> Importing 4 features (OGR layer <r848659>)...
> 3005 primitives registered
> 15587 vertices registered
> Number of nodes: 2691
> Number of primitives: 3005
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 3005
> Number of areas: -
> Number of isles: -
> Cleaning polygons
> Removing dangles...
> Building areas...
> 95 areas built
> 8 isles built
> Number of nodes: 2771
> Number of primitives: 7307
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 7307
> Number of areas: 95
> Number of isles: 8
> Removing bridges...
> 231 primitives registered
> 7594 vertices registered
> Building areas...
> 95 areas built
> 8 isles built
> Number of nodes: 144
> Number of primitives: 231
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 231
> Number of areas: 95
> Number of isles: 8
> Finding centroids for OGR layer <r848659>...
> 95 input polygons
> Total area: 1.28981E+006 (95 areas)
> Copying features...
> 'C:/Users/ediez1/AppData/Local/Temp/Rtmpg10lvi/filec2473b0126/filec24129b63ac/.tmp/unknown/vector/tmp_10484/coor'
> Building topology for vector map <r848659 at filec24129b63ac>...
> 326 primitives registered
> 7689 vertices registered
> Building areas...
> 95 areas built
> 8 isles built
> Number of primitives: 326
> Number of points: 0
> Number of lines: 0
> Number of centroids: 95
> Number of areas: 95
> Number of isles: 8
> > execGRASS("v.clean", flags = c("overwrite"), input = "pol1",
> + output = "clnpol", tool = "rmarea", threshold = 3000)
> Tool: Threshold
> Copying features...
> Building topology for vector map <k1f9f75 at filec24129b63ac>...
> Building areas...
> 95 areas built
> 8 isles built
> Number of points: 0
> Number of lines: 0
> Number of areas: 95
> Number of isles: 8
> 55 areas of total size 29487.1 removed
> 212 primitives registered
> 6840 vertices registered
> Building areas...
> 40 areas built
> 4 isles built
> Number of nodes: 136
> Number of primitives: 212
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 172
> Number of centroids: 40
> Number of areas: 40
> Number of isles: 4
> > cln.pol <- readVECT("clnpol")
> > cln.pol <- readVECT("clnpol", driver = "ESRI Shapefile")
> na.strings, :
> > sessionInfo()
> locale:
> States.1252
> [1] rgrass7_0.1-2 classInt_0.1-22 maptools_0.8-36 ggplot2_1.0.1
> XML_3.98-1.3 raster_2.4-20 sp_1.2-0
> [1] Rcpp_0.12.1 magrittr_1.5 MASS_7.3-43 munsell_0.4.2
> colorspace_1.2-6 lattice_0.20-33 stringr_1.0.0 plyr_1.8.3
> [9] tools_3.2.2 parallel_3.2.2 rgdal_1.0-7 grid_3.2.2
> gtable_0.1.2 e1071_1.6-7 class_7.3-13 rgeos_0.3-12
> [17] digest_0.6.8 reshape2_1.4.1 labeling_0.3 stringi_0.5-5
> scales_0.3.0 foreign_0.8-65 proto_0.3-10
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20151009/a279f6d8/attachment-0001.html>
More information about the grass-stats
