[GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames errors
Roger Bivand Roger.Bivand at nhh.no
Fri Oct 9 07:27:53 PDT 2015
OK, please provide the output of traceback() run immediately after the failing readVECT(). That will show which command invokes scan(). Also try to run vInfo(zm.gnrl) - I think the failure is in:
execGRASS("v.info", flags="t", map="zm.gnrl", layer=1L)
not returning a structure that vInfo understands, and which ois then used in readVECT().
Roger
Roger Bivand
Norwegian School of Economics
Helleveien 30, 5045 Bergen, Norway
Fra: diez.edu at gmail.com [diez.edu at gmail.com] på vegne av Eduardo Diez [eduardodiez at gmx.com]
Sendt: 9. oktober 2015 4:04
Til: Roger Bivand
Kopi: grass-stats at lists.osgeo.org
Emne: Re: [GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames errors
Roger, with GRASS version 7.0.1 and rgrass7_0.1-3, readVECT now doesn't ask for the driver to use but gives the same error as before:
writeVECT(SDF = mz.pol, vname = zm.pol, v.in.ogr_flags = "o")
Over-riding projection check
Check if OGR layer <q7468fb> contains polygons...
Importing 205 features (OGR layer <q7468fb>)...
Registering primitives...
3924 primitives registered
12866 vertices registered
Number of nodes: 2884
Number of primitives: 3924
Number of points: 0
Number of lines: 0
Number of boundaries: 3924
Number of centroids: 0
Number of areas: -
Number of isles: -
Cleaning polygons
Breaking polygons...
Breaking polygons (pass 1: select break points)...
Breaking polygons (pass 2: break at selected points)...
Removing duplicates...
Breaking boundaries...
Cleaning boundaries at nodes...
Merging boundaries...
Removing dangles...
Building areas...
205 areas built
13 isles built
Number of nodes: 2929
Number of primitives: 7268
Number of points: 0
Number of lines: 0
Number of boundaries: 7268
Number of areas: 205
Number of isles: 13
Removing bridges...
498 primitives registered
5828 vertices registered
Building areas...
205 areas built
13 isles built
Attaching islands...
Number of nodes: 306
Number of primitives: 498
Number of points: 0
Number of lines: 0
Number of boundaries: 498
Number of isles: 13
Finding centroids for OGR layer <q7468fb>...
Writing centroids...
205 input polygons
Total area: 1.25187E+006 (205 areas)
Copying features...
WARNING: Unable to delete file
         'C:/Users/ediez1/AppData/Local/Temp/Rtmpqkeay4/file480c1e5e16a7/file480c11cc233b/.tmp/unknown/vector/tmp_8308/coor'
Building topology for vector map <q7468fb at file480c11cc233b>...
703 primitives registered
6033 vertices registered
Building areas...
205 areas built
13 isles built
Attaching centroids...
Number of primitives: 703
Number of points: 0
Number of lines: 0
Number of centroids: 205
Number of isles: 13
> execGRASS("v.clean", flags = c("overwrite"), input = zm.pol,
+ output = zm.gnrl, tool = "rmarea", threshold = 3000)
Tool: Threshold
Remove small areas: 3000
Copying features...
Rebuilding parts of topology...
Building topology for vector map <u10f44b at file480c11cc233b>...
Building areas...
205 areas built
13 isles built
Number of points: 0
Number of lines: 0
Number of isles: 13
Tool: Remove small areas
174 areas of total size 50601.7 removed
Rebuilding topology for output vector map...
333 primitives registered
4705 vertices registered
Building areas...
31 areas built
3 isles built
Number of nodes: 274
Number of primitives: 333
Number of points: 0
Number of lines: 0
Number of boundaries: 302
Number of centroids: 31
Number of areas: 31
Number of isles: 3
> zm.fnl <- readVECT(zm.gnrl)
Error in scan(file, what, nmax, sep, dec, quote, skip, nlines, na.strings,  :
  line 4 did not have 2 elements
> sessionInfo()
R version 3.2.2 (2015-08-14)
Platform: x86_64-w64-mingw32/x64 (64-bit)
Running under: Windows 7 x64 (build 7601) Service Pack 1
locale:
[1] LC_COLLATE=English_United States.1252  LC_CTYPE=English_United States.1252    LC_MONETARY=English_United States.1252
[4] LC_NUMERIC=C                           LC_TIME=English_United States.1252
attached base packages:
[1] stats     graphics  grDevices utils     datasets  methods   base
other attached packages:
 [1] RPyGeo_0.9-3    RSAGA_0.94-3    plyr_1.8.3      gstat_1.0-26    shapefiles_0.7  foreign_0.8-65  maptools_0.8-37 rgdal_1.0-7     classInt_0.1-23
[10] raster_2.4-20   rgrass7_0.1-3   XML_3.98-1.3    sp_1.2-0
loaded via a namespace (and not attached):
 [1] Rcpp_0.12.1      intervals_0.15.1 lattice_0.20-33  FNN_1.1          spacetime_1.1-4  class_7.3-13     zoo_1.7-12       grid_3.2.2
 [9] e1071_1.6-7      xts_0.9-7        tools_3.2.2
Thanks
2015-10-08 18:57 GMT-03:00 Roger Bivand
<Roger.Bivand at nhh.no>:
Sorry this has taken a long time; please try installing the development version available from:
http://win-builder.r-project.org/8Y3Ihj451Clx
(rgrass7_0.1-3.zip). The problem was the use of "_" instead of " " in the name of the OGR shapefile driver - in OGR and R it is "ESRI Shapefile", in GRASS it is "ESRI_Shapefile". Because the new long-name work-around worked on systems not needing to use this
 driver, it wasn't properly tested - and on Windows the GRASS standalone has OGR with the SQLite driver, but the Windows rgdal binary does not have SQLite. You may wish to install the R RSQLite package to move data if you use long field/column names.
Before installing this development version, and after library(rgrass7), run example(readVECT) in the basic nc location from:
https://grass.osgeo.org/sampledata/north_carolina/nc_basic_spm_grass7.zip
it should fail. Then restart R, install the development version of rgrass7 from the first link, and repeat - it works for me and should resolve the problem.
Hope this helps,
Roger
Roger Bivand
Fra:
grass-stats-bounces at lists.osgeo.org [grass-stats-bounces at lists.osgeo.org]
Sendt: 24. september 2015 9:11
Til:
Emne: [GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames errors
Hi, I'm a user of R mostly for spatial information processing. Besides sp, maptools, etc. i also use functions from GRASS, at first through spgrass6 and then rgrass7. A few days ago, I started having trouble reading and writing SpatialPolygonsDataFrames using
 readVECT and writeVECT. I tried both reinstalling both grass (6.4.4, 7.0.0 and 7.0.1) and the R packages (spgrass6 0.8-6 and rgrass7 0.1-2), and also with different R objects but i kept getting the same errors.
The "mult.r" object is a RasterLayer with 4 zones and the objective is to convert it to polygons and "clean" small areas with v.clean rmarea (as i don't currently know a way of doing this in plain R).
The first thing that came out strange was that when executing writeVECT it would ask me for the driver to use (in the way of rgdal's writeOGR, it didn't ask for it before). I figured out that object to be written should be projected (not in lat-lon, don't know
 why). After doing this i could write the vector and execute v.clean. The problem came again when trying to read the cleaned polygons back to R.
Below i paste an extract of my R console with the errors and some information.
Thanks in advance,
Eduardo
> mult.rp <- projectRaster(mult.r, crs = prj.crs, method = "ngb")
> mult.pol <- rasterToPolygons(mult.rp, dissolve = T)
> initGRASS(gisBase = "c:/Program Files (x86)/GRASS GIS 7.0.1", home = tempdir(), override = T)
gisdbase    C:/Users/ediez1/AppData/Local/Temp/RtmpegbyiQ
location    file2f7c6dc070e6
mapset      file2f7c30eb3f52
rows        1
columns     1
north       1
south       0
west        0
east        1
nsres       1
ewres       1
projection  NA
> writeVECT(mult.pol, "pol1", v.in.ogr_flags = "o")
Error: !is.null(driver) is not TRUE
> writeVECT(mult.pol, "pol1", v.in.ogr_flags = "o", driver = "ESRI Shapefile")
Check if OGR layer <r848659> contains polygons...
Importing 4 features (OGR layer <r848659>)...
3005 primitives registered
15587 vertices registered
Number of nodes: 2691
Number of primitives: 3005
Number of points: 0
Number of lines: 0
Number of boundaries: 3005
Number of areas: -
Number of isles: -
Cleaning polygons
Removing dangles...
Building areas...
95 areas built
8 isles built
Number of nodes: 2771
Number of primitives: 7307
Number of points: 0
Number of lines: 0
Number of boundaries: 7307
Number of areas: 95
Number of isles: 8
Removing bridges...
231 primitives registered
7594 vertices registered
Building areas...
95 areas built
8 isles built
Number of nodes: 144
Number of primitives: 231
Number of points: 0
Number of lines: 0
Number of boundaries: 231
Number of areas: 95
Number of isles: 8
Finding centroids for OGR layer <r848659>...
95 input polygons
Total area: 1.28981E+006 (95 areas)
Copying features...
         'C:/Users/ediez1/AppData/Local/Temp/Rtmpg10lvi/filec2473b0126/filec24129b63ac/.tmp/unknown/vector/tmp_10484/coor'
Building topology for vector map <r848659 at filec24129b63ac>...
326 primitives registered
7689 vertices registered
Building areas...
95 areas built
8 isles built
Number of primitives: 326
Number of points: 0
Number of lines: 0
Number of centroids: 95
Number of areas: 95
Number of isles: 8
> execGRASS("v.clean", flags = c("overwrite"), input = "pol1",
+ output = "clnpol", tool = "rmarea", threshold = 3000)
Tool: Threshold
Copying features...
Building topology for vector map <k1f9f75 at filec24129b63ac>...
Building areas...
95 areas built
8 isles built
Number of points: 0
Number of lines: 0
Number of areas: 95
Number of isles: 8
55 areas of total size 29487.1 removed
212 primitives registered
6840 vertices registered
Building areas...
40 areas built
4 isles built
Number of nodes: 136
Number of primitives: 212
Number of points: 0
Number of lines: 0
Number of boundaries: 172
Number of centroids: 40
Number of areas: 40
Number of isles: 4
> cln.pol <- readVECT("clnpol")
> cln.pol <- readVECT("clnpol", driver = "ESRI Shapefile")
> sessionInfo()
locale:
[1] rgrass7_0.1-2   classInt_0.1-22 maptools_0.8-36 ggplot2_1.0.1   XML_3.98-1.3    raster_2.4-20   sp_1.2-0
 [1] Rcpp_0.12.1      magrittr_1.5     MASS_7.3-43      munsell_0.4.2    colorspace_1.2-6 lattice_0.20-33  stringr_1.0.0    plyr_1.8.3
 [9] tools_3.2.2      parallel_3.2.2   rgdal_1.0-7      grid_3.2.2       gtable_0.1.2     e1071_1.6-7      class_7.3-13     rgeos_0.3-12
[17] digest_0.6.8     reshape2_1.4.1   labeling_0.3     stringi_0.5-5    scales_0.3.0     foreign_0.8-65   proto_0.3-10
More information about the grass-stats mailing list
