[GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames	errors
    Eduardo Diez
    eduardodiez at gmx.com
    Sat Oct 10 09:20:21 PDT 2015
This is what i got:
> vinfo0 <- execGRASS("v.info", flags="c", map=zm.gnrl)INTEGER|cat
INTEGER|ID
INTEGER|GRIDCODE
Displaying column types/names for database connection of layer <1>:
And trying to read back the original polygon (without v.clean):
> zm.fnl <- readVECT(zm.pol)Error in scan(file, what, nmax, sep, dec, quote, skip, nlines, na.strings,  :
  line 4 did not have 2 elements
2015-10-10 13:12 GMT-03:00 Roger Bivand <Roger.Bivand at nhh.no>:
> On Sat, 10 Oct 2015, Eduardo Diez wrote:
> Apparently "v.info" through execGRASS is expecting the "layer" argument to
>> be a string rather than an integer.
> Yes, please re-run with "1"; this resulted from GRASS6 to GRASS7
> over-enthusiastic changing everything just for fun - this isn't the
> problem. Run (assuming that zm.gnrl contains a character string):
> My guess is that v.info is saying that this map is broken, or suffering
> from something that vColumns does not know about.
> v.info -c map=
> should simply respond with "<storage type>|<name>" lines for the fields in
> the layer. Here, its fourth line (unlike the first three) does not have two
> elements (the type/name pairs).
> Does readVECT() work if you do not use v.clean? Is v.clean having a side
> effect of causing v.info -c to "say" something else? How should the input
> columns of the object to be cleaned be turned into output columns (simply
> copy across the retained areas?)?
> Roger
>> zm.fnl <- readVECT(zm.gnrl)Error in scan(file, what, nmax, sep, dec,
>>  line 4 did not have 2 elements> vinfo0 <- execGRASS("v.info",
>> flags="c", map=zm.gnrl, layer=1L,+ intern=TRUE)Error in doGRASS(cmd,
>> flags = flags, ..., parameters = parameters, echoCmd = echoCmd,  :
>>  Parameter <layer> does not have string value>
>> parseGRASS("v.info")Command: v.info
>> Extension: .exe
>> Description: Outputs basic information about a vector map.
>> Keywords: vector, metadata, topology, extent, history, attribute columns
>> Parameters:
>>  name: map, type: string, required: yes, multiple: no
>>  keydesc: name, keydesc_count: 1
>> [Or data source for direct OGR access]
>>  name: layer, type: string, required: no, multiple: no
>>  default: 1
>> [Vector features can have category values in different layers. This
>> number determines which layer to use. When used with direct OGR access
>> this is the layer name.]
>> Flags:
>>  name: h [Print history instead of info and exit] {FALSE}
>>  name: c [Print types/names of table columns for specified layer
>>  name: g [Print region info in shell script style] {FALSE}
>>  name: e [Print extended metadata info in shell script style] {FALSE}
>>  name: t [Print topology info in shell script style] {FALSE}
>>  name: help [Print usage summary] {FALSE}
>>  name: verbose [Verbose module output] {FALSE}
>>  name: quiet [Quiet module output] {FALSE}
>> 2015-10-10 10:56 GMT-03:00 Roger Bivand <Roger.Bivand at nhh.no>:
>> OK, thanks. So the failure is in:
>>> vinfo0 <- execGRASS("v.info", flags="c", map="<name>", layer=1L,
>>>   intern=TRUE)
>>> used to return the column/field names. Please repeat with that.
>>> Roger
>>> On Fri, 9 Oct 2015, Eduardo Diez wrote:
>>> Here are the traceback and the vInfo(zm.gnrl). The latter seems to work
>>>> fine.
>>>> na.strings,
>>>> traceback()
>>>>> 8: scan(file = file, what = what, sep = sep, quote = quote, dec = dec,
>>>>       nmax = nrows, skip = 0, na.strings = na.strings, quiet = TRUE,
>>>>       fill = fill, strip.white = strip.white, blank.lines.skip =
>>>> blank.lines.skip,
>>>>       multi.line = FALSE, comment.char = comment.char, allowEscapes =
>>>> allowEscapes,
>>>>       flush = flush, encoding = encoding, skipNul = skipNul)
>>>> 7: read.table(con, header = FALSE, sep = "|")
>>>> 6: vColumns(vname)
>>>> 5: nchar(as.character(vColumns(vname)$name))
>>>> 4: .read_vect_non_plugin(vname = vname, layer = layer, type = type,
>>>>       remove.duplicates = remove.duplicates, ignore.stderr =
>>>> ignore.stderr,
>>>>       pointDropZ = pointDropZ, driver = driver, with_prj = with_prj,
>>>>       with_c = with_c)
>>>> 3: tryCatchList(expr, classes, parentenv, handlers)
>>>> 2: tryCatch({
>>>>       stopifnot(is.logical(plugin) || is.null(plugin))
>>>>       stopifnot(is.logical(ignore.stderr))
>>>>       if (missing(layer))
>>>>           layer <- 1L
>>>>       layer <- as.character(layer)
>>>>       stopifnot(is.logical(with_c))
>>>>       if (!is.null(driver) && driver == "GRASS")
>>>>           plugin <- TRUE
>>>>       if (!requireNamespace("rgdal", quietly = TRUE)) {
>>>>           stop("rgdal not available")
>>>>       if (is.null(plugin)) {
>>>>           ogrD <- rgdal::ogrDrivers()$name
>>>>           plugin <- "GRASS" %in% ogrD
>>>>       if (plugin) {
>>>>           res <- .read_vect_plugin(vname = vname, layer = layer,
>>>>               type = type, ignore.stderr = ignore.stderr, pointDropZ =
>>>> pointDropZ,
>>>>               mapset = mapset)
>>>>       else {
>>>>           res <- .read_vect_non_plugin(vname = vname, layer = layer,
>>>>               type = type, remove.duplicates = remove.duplicates,
>>>>               ignore.stderr = ignore.stderr, pointDropZ = pointDropZ,
>>>>               driver = driver, with_prj = with_prj, with_c = with_c)
>>>>   }, finally = {
>>>>       if (get.suppressEchoCmdInFuncOption()) {
>>>>           tull <- set.echoCmdOption(inEchoCmd)
>>>> 1: readVECT(zm.gnrl)
>>>> vInfo(zm.gnrl)
>>>>>     nodes     points      lines boundaries  centroids      areas
>>>> islands primitives      map3d
>>>>       274          0          0        302         31         31
>>>> 3        333          0
>>>> Thanks
>>>> 2015-10-09 11:36 GMT-03:00 Roger Bivand <Roger.Bivand at nhh.no>:
>>>> If it is the v.info call, please run:
>>>>> res <- execGRASS("v.info", flags="t", map="zm.gnrl", layer=1L,
>>>>> intern=TRUE)
>>>>> and report the output of:
>>>>> print(res)
>>>>> and maybe send me offlist the output of
>>>>> save(res, file="vinfo_odd_output.RData")
>>>>> Roger
>>>>> Roger Bivand
>>>>> Norwegian School of Economics
>>>>> Helleveien 30, 5045 Bergen, Norway
>>>>> ________________________________________
>>>>> Fra: grass-stats [grass-stats-bounces at lists.osgeo.org] på vegne
>>>>> av
>>>>> Roger Bivand [Roger.Bivand at nhh.no]
>>>>> Sendt: 9. oktober 2015 4:27
>>>>> Til: Eduardo Diez
>>>>> Kopi: grass-stats at lists.osgeo.org
>>>>> Emne: Re: [GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames
>>>>> errors
>>>>> OK, please provide the output of traceback() run immediately after the
>>>>> failing readVECT(). That will show which command invokes scan(). Also
>>>>> try
>>>>> to run vInfo(zm.gnrl) - I think the failure is in:
>>>>> execGRASS("v.info", flags="t", map="zm.gnrl", layer=1L)
>>>>> not returning a structure that vInfo understands, and which ois then
>>>>> used
>>>>> in readVECT().
>>>>> Roger
>>>>> Roger Bivand
>>>>> Fra: diez.edu at gmail.com [diez.edu at gmail.com] på vegne av Eduardo Diez
>>>>> eduardodiez at gmx.com]
>>>>> Sendt: 9. oktober 2015 4:04
>>>>> Til: Roger Bivand
>>>>> errors
>>>>> Roger, with GRASS version 7.0.1 and rgrass7_0.1-3, readVECT now doesn't
>>>>> ask for the driver to use but gives the same error as before:
>>>>> writeVECT(SDF = mz.pol, vname = zm.pol, v.in.ogr_flags = "o")
>>>>> Over-riding projection check
>>>>> Check if OGR layer <q7468fb> contains polygons...
>>>>> Importing 205 features (OGR layer <q7468fb>)...
>>>>> Registering primitives...
>>>>> 3924 primitives registered
>>>>> 12866 vertices registered
>>>>> Number of nodes: 2884
>>>>> Number of primitives: 3924
>>>>> Number of points: 0
>>>>> Number of lines: 0
>>>>> Number of boundaries: 3924
>>>>> Number of centroids: 0
>>>>> Number of areas: -
>>>>> Number of isles: -
>>>>> Cleaning polygons
>>>>> Breaking polygons...
>>>>> Breaking polygons (pass 1: select break points)...
>>>>> Breaking polygons (pass 2: break at selected points)...
>>>>> Removing duplicates...
>>>>> Breaking boundaries...
>>>>> Cleaning boundaries at nodes...
>>>>> Merging boundaries...
>>>>> Removing dangles...
>>>>> Building areas...
>>>>> 205 areas built
>>>>> 13 isles built
>>>>> Number of nodes: 2929
>>>>> Number of primitives: 7268
>>>>> Number of points: 0
>>>>> Number of lines: 0
>>>>> Number of boundaries: 7268
>>>>> Number of areas: 205
>>>>> Number of isles: 13
>>>>> Removing bridges...
>>>>> 498 primitives registered
>>>>> 5828 vertices registered
>>>>> Building areas...
>>>>> 205 areas built
>>>>> 13 isles built
>>>>> Attaching islands...
>>>>> Number of nodes: 306
>>>>> Number of primitives: 498
>>>>> Number of points: 0
>>>>> Number of lines: 0
>>>>> Number of boundaries: 498
>>>>> Number of isles: 13
>>>>> Finding centroids for OGR layer <q7468fb>...
>>>>> Writing centroids...
>>>>> 205 input polygons
>>>>> Total area: 1.25187E+006 (205 areas)
>>>>> Copying features...
>>>>> WARNING: Unable to delete file
>>>>>  'C:/Users/ediez1/AppData/Local/Temp/Rtmpqkeay4/file480c1e5e16a7/file480c11cc233b/.tmp/unknown/vector/tmp_8308/coor'
>>>>> Building topology for vector map <q7468fb at file480c11cc233b>...
>>>>> 703 primitives registered
>>>>> 6033 vertices registered
>>>>> Building areas...
>>>>> 205 areas built
>>>>> 13 isles built
>>>>> Attaching centroids...
>>>>> Number of primitives: 703
>>>>> Number of points: 0
>>>>> Number of lines: 0
>>>>> Number of centroids: 205
>>>>> Number of isles: 13
>>>>> execGRASS("v.clean", flags = c("overwrite"), input = zm.pol,
>>>>>> + output = zm.gnrl, tool = "rmarea", threshold = 3000)
>>>>> Tool: Threshold
>>>>> Remove small areas: 3000
>>>>> Copying features...
>>>>> Rebuilding parts of topology...
>>>>> Building topology for vector map <u10f44b at file480c11cc233b>...
>>>>> Building areas...
>>>>> 205 areas built
>>>>> 13 isles built
>>>>> Number of points: 0
>>>>> Number of lines: 0
>>>>> Number of isles: 13
>>>>> Tool: Remove small areas
>>>>> 174 areas of total size 50601.7 removed
>>>>> Rebuilding topology for output vector map...
>>>>> 333 primitives registered
>>>>> 4705 vertices registered
>>>>> Building areas...
>>>>> 31 areas built
>>>>> 3 isles built
>>>>> Number of nodes: 274
>>>>> Number of primitives: 333
>>>>> Number of points: 0
>>>>> Number of lines: 0
>>>>> Number of boundaries: 302
>>>>> Number of centroids: 31
>>>>> Number of areas: 31
>>>>> Number of isles: 3
>>>>> na.strings,  :
>>>>> sessionInfo()
>>>>>> R version 3.2.2 (2015-08-14)
>>>>> Platform: x86_64-w64-mingw32/x64 (64-bit)
>>>>> Running under: Windows 7 x64 (build 7601) Service Pack 1
>>>>> locale:
>>>>> [1] LC_COLLATE=English_United States.1252  LC_CTYPE=English_United
>>>>> States.1252    LC_MONETARY=English_United States.1252
>>>>> [4] LC_NUMERIC=C                           LC_TIME=English_United
>>>>> States.1252
>>>>> attached base packages:
>>>>> [1] stats     graphics  grDevices utils     datasets  methods   base
>>>>> other attached packages:
>>>>>  [1] RPyGeo_0.9-3    RSAGA_0.94-3    plyr_1.8.3      gstat_1.0-26
>>>>> shapefiles_0.7  foreign_0.8-65  maptools_0.8-37 rgdal_1.0-7
>>>>>  classInt_0.1-23
>>>>> [10] raster_2.4-20   rgrass7_0.1-3   XML_3.98-1.3    sp_1.2-0
>>>>> loaded via a namespace (and not attached):
>>>>>  [1] Rcpp_0.12.1      intervals_0.15.1 lattice_0.20-33  FNN_1.1
>>>>> spacetime_1.1-4  class_7.3-13     zoo_1.7-12       grid_3.2.2
>>>>>  [9] e1071_1.6-7      xts_0.9-7        tools_3.2.2
>>>>> Thanks
>>>>> 2015-10-08 18:57 GMT-03:00 Roger Bivand
>>>>> Sorry this has taken a long time; please try installing the development
>>>>> version available from:
>>>>> http://win-builder.r-project.org/8Y3Ihj451Clx
>>>>> (rgrass7_0.1-3.zip). The problem was the use of "_" instead of " " in
>>>>> the
>>>>> name of the OGR shapefile driver - in OGR and R it is "ESRI Shapefile",
>>>>> in
>>>>> GRASS it is "ESRI_Shapefile". Because the new long-name work-around
>>>>> worked
>>>>> on systems not needing to use this
>>>>>  driver, it wasn't properly tested - and on Windows the GRASS
>>>>> standalone
>>>>> has OGR with the SQLite driver, but the Windows rgdal binary does not
>>>>> have
>>>>> SQLite. You may wish to install the R RSQLite package to move data if
>>>>> you
>>>>> use long field/column names.
>>>>> Before installing this development version, and after library(rgrass7),
>>>>> run example(readVECT) in the basic nc location from:
>>>>> https://grass.osgeo.org/sampledata/north_carolina/nc_basic_spm_grass7.zip
>>>>> it should fail. Then restart R, install the development version of
>>>>> rgrass7
>>>>> from the first link, and repeat - it works for me and should resolve
>>>>> the
>>>>> problem.
>>>>> Hope this helps,
>>>>> Roger
>>>>> Roger Bivand
>>>>> Fra:
>>>>> grass-stats-bounces at lists.osgeo.org [
>>>>>  på vegne av Eduardo Diez [eduardodiez at gmx.com]
>>>>> Sendt: 24. september 2015 9:11
>>>>> Til:
>>>>> Emne: [GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames errors
>>>>> Hi, I'm a user of R mostly for spatial information processing. Besides
>>>>> sp,
>>>>> maptools, etc. i also use functions from GRASS, at first through
>>>>> spgrass6
>>>>> and then rgrass7. A few days ago, I started having trouble reading and
>>>>> writing SpatialPolygonsDataFrames using
>>>>>  readVECT and writeVECT. I tried both reinstalling both grass (6.4.4,
>>>>> 7.0.0 and 7.0.1) and the R packages (spgrass6 0.8-6 and rgrass7 0.1-2),
>>>>> and
>>>>> also with different R objects but i kept getting the same errors.
>>>>> The "mult.r" object is a RasterLayer with 4 zones and the objective is
>>>>> to
>>>>> convert it to polygons and "clean" small areas with v.clean rmarea (as
>>>>> i
>>>>> don't currently know a way of doing this in plain R).
>>>>> The first thing that came out strange was that when executing writeVECT
>>>>> it
>>>>> would ask me for the driver to use (in the way of rgdal's writeOGR, it
>>>>> didn't ask for it before). I figured out that object to be written
>>>>> should
>>>>> be projected (not in lat-lon, don't know
>>>>>  why). After doing this i could write the vector and execute v.clean.
>>>>> The
>>>>> problem came again when trying to read the cleaned polygons back to R.
>>>>> Below i paste an extract of my R console with the errors and some
>>>>> information.
>>>>> Thanks in advance,
>>>>> Eduardo
>>>>> mult.rp <- projectRaster(mult.r, crs = prj.crs, method = "ngb")
>>>>> mult.pol <- rasterToPolygons(mult.rp, dissolve = T)
>>>>> initGRASS(gisBase = "c:/Program Files (x86)/GRASS GIS 7.0.1", home =
>>>>>> tempdir(), override = T)
>>>>> gisdbase    C:/Users/ediez1/AppData/Local/Temp/RtmpegbyiQ
>>>>> location    file2f7c6dc070e6
>>>>> mapset      file2f7c30eb3f52
>>>>> rows        1
>>>>> columns     1
>>>>> north       1
>>>>> south       0
>>>>> west        0
>>>>> east        1
>>>>> nsres       1
>>>>> ewres       1
>>>>> projection  NA
>>>>> writeVECT(mult.pol, "pol1", v.in.ogr_flags = "o")
>>>>> Error: !is.null(driver) is not TRUE
>>>>> writeVECT(mult.pol, "pol1", v.in.ogr_flags = "o", driver = "ESRI
>>>>>> Shapefile")
>>>>> Check if OGR layer <r848659> contains polygons...
>>>>> Importing 4 features (OGR layer <r848659>)...
>>>>> 3005 primitives registered
>>>>> 15587 vertices registered
>>>>> Number of nodes: 2691
>>>>> Number of primitives: 3005
>>>>> Number of points: 0
>>>>> Number of lines: 0
>>>>> Number of boundaries: 3005
>>>>> Number of areas: -
>>>>> Number of isles: -
>>>>> Cleaning polygons
>>>>> Removing dangles...
>>>>> Building areas...
>>>>> 95 areas built
>>>>> 8 isles built
>>>>> Number of nodes: 2771
>>>>> Number of primitives: 7307
>>>>> Number of points: 0
>>>>> Number of lines: 0
>>>>> Number of boundaries: 7307
>>>>> Number of areas: 95
>>>>> Number of isles: 8
>>>>> Removing bridges...
>>>>> 231 primitives registered
>>>>> 7594 vertices registered
>>>>> Building areas...
>>>>> 95 areas built
>>>>> 8 isles built
>>>>> Number of nodes: 144
>>>>> Number of primitives: 231
>>>>> Number of points: 0
>>>>> Number of lines: 0
>>>>> Number of boundaries: 231
>>>>> Number of areas: 95
>>>>> Number of isles: 8
>>>>> Finding centroids for OGR layer <r848659>...
>>>>> 95 input polygons
>>>>> Total area: 1.28981E+006 (95 areas)
>>>>> Copying features...
>>>>>  'C:/Users/ediez1/AppData/Local/Temp/Rtmpg10lvi/filec2473b0126/filec24129b63ac/.tmp/unknown/vector/tmp_10484/coor'
>>>>> Building topology for vector map <r848659 at filec24129b63ac>...
>>>>> 326 primitives registered
>>>>> 7689 vertices registered
>>>>> Building areas...
>>>>> 95 areas built
>>>>> 8 isles built
>>>>> Number of primitives: 326
>>>>> Number of points: 0
>>>>> Number of lines: 0
>>>>> Number of centroids: 95
>>>>> Number of areas: 95
>>>>> Number of isles: 8
>>>>> execGRASS("v.clean", flags = c("overwrite"), input = "pol1",
>>>>> + output = "clnpol", tool = "rmarea", threshold = 3000)
>>>>> Tool: Threshold
>>>>> Copying features...
>>>>> Building topology for vector map <k1f9f75 at filec24129b63ac>...
>>>>> Building areas...
>>>>> 95 areas built
>>>>> 8 isles built
>>>>> Number of points: 0
>>>>> Number of lines: 0
>>>>> Number of areas: 95
>>>>> Number of isles: 8
>>>>> 55 areas of total size 29487.1 removed
>>>>> 212 primitives registered
>>>>> 6840 vertices registered
>>>>> Building areas...
>>>>> 40 areas built
>>>>> 4 isles built
>>>>> Number of nodes: 136
>>>>> Number of primitives: 212
>>>>> Number of points: 0
>>>>> Number of lines: 0
>>>>> Number of boundaries: 172
>>>>> Number of centroids: 40
>>>>> Number of areas: 40
>>>>> Number of isles: 4
>>>>> cln.pol <- readVECT("clnpol")
>>>>> cln.pol <- readVECT("clnpol", driver = "ESRI Shapefile")
>>>>> na.strings,  :
>>>>> sessionInfo()
>>>>> locale:
>>>>> States.1252
>>>>> [1] rgrass7_0.1-2   classInt_0.1-22 maptools_0.8-36 ggplot2_1.0.1
>>>>>  XML_3.98-1.3    raster_2.4-20   sp_1.2-0
>>>>>  [1] Rcpp_0.12.1      magrittr_1.5     MASS_7.3-43      munsell_0.4.2
>>>>> colorspace_1.2-6 lattice_0.20-33  stringr_1.0.0    plyr_1.8.3
>>>>>  [9] tools_3.2.2      parallel_3.2.2   rgdal_1.0-7      grid_3.2.2
>>>>>  gtable_0.1.2     e1071_1.6-7      class_7.3-13     rgeos_0.3-12
>>>>> [17] digest_0.6.8     reshape2_1.4.1   labeling_0.3     stringi_0.5-5
>>>>> scales_0.3.0     foreign_0.8-65   proto_0.3-10
>>>>> _______________________________________________
>>>>> grass-stats mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-stats
>>> Roger Bivand
>>> Department of Economics, Norwegian School of Economics,
>>> Helleveien 30, N-5045 Bergen, Norway.
>>> voice: +47 55 95 93 55; fax +47 55 95 91 00
>>> e-mail: Roger.Bivand at nhh.no
> Roger Bivand
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20151010/1320da9e/attachment-0001.html>
More information about the grass-stats
