[GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames errors
Roger Bivand Roger.Bivand at nhh.no
Sat Oct 10 09:12:45 PDT 2015
On Sat, 10 Oct 2015, Eduardo Diez wrote:
> Apparently "v.info" through execGRASS is expecting the "layer" argument to
> be a string rather than an integer.
Yes, please re-run with "1"; this resulted from GRASS6 to GRASS7
over-enthusiastic changing everything just for fun - this isn't the
problem. Run (assuming that zm.gnrl contains a character string):
vinfo0 <- execGRASS("v.info", flags="c", map=zm.gnrl)
My guess is that v.info is saying that this map is broken, or suffering
from something that vColumns does not know about.
v.info -c map=
should simply respond with "<storage type>|<name>" lines for the fields in
the layer. Here, its fourth line (unlike the first three) does not have
two elements (the type/name pairs).
Does readVECT() work if you do not use v.clean? Is v.clean having a side
effect of causing v.info -c to "say" something else? How should the input
columns of the object to be cleaned be turned into output columns (simply
copy across the retained areas?)?
Roger
>> zm.fnl <- readVECT(zm.gnrl)Error in scan(file, what, nmax, sep, dec, quote, skip, nlines, na.strings,  :
>  line 4 did not have 2 elements> vinfo0 <- execGRASS("v.info",
> flags="c", map=zm.gnrl, layer=1L,+ intern=TRUE)Error in doGRASS(cmd,
> flags = flags, ..., parameters = parameters, echoCmd = echoCmd,  :
>  Parameter <layer> does not have string value>
> parseGRASS("v.info")Command: v.info
> Extension: .exe
> Description: Outputs basic information about a vector map.
> Keywords: vector, metadata, topology, extent, history, attribute columns
> Parameters:
>  name: map, type: string, required: yes, multiple: no
>  keydesc: name, keydesc_count: 1
> [Or data source for direct OGR access]
>  name: layer, type: string, required: no, multiple: no
>  default: 1
> [Vector features can have category values in different layers. This
> number determines which layer to use. When used with direct OGR access
> this is the layer name.]
> Flags:
>  name: h [Print history instead of info and exit] {FALSE}
>  name: c [Print types/names of table columns for specified layer
>  name: g [Print region info in shell script style] {FALSE}
>  name: e [Print extended metadata info in shell script style] {FALSE}
>  name: t [Print topology info in shell script style] {FALSE}
>  name: help [Print usage summary] {FALSE}
>  name: verbose [Verbose module output] {FALSE}
>  name: quiet [Quiet module output] {FALSE}
> 2015-10-10 10:56 GMT-03:00 Roger Bivand <Roger.Bivand at nhh.no>:
>> OK, thanks. So the failure is in:
>> vinfo0 <- execGRASS("v.info", flags="c", map="<name>", layer=1L,
>>   intern=TRUE)
>> used to return the column/field names. Please repeat with that.
>> Roger
>> On Fri, 9 Oct 2015, Eduardo Diez wrote:
>> Here are the traceback and the vInfo(zm.gnrl). The latter seems to work
>>> fine.
>>>> traceback()
>>> 8: scan(file = file, what = what, sep = sep, quote = quote, dec = dec,
>>>       nmax = nrows, skip = 0, na.strings = na.strings, quiet = TRUE,
>>>       fill = fill, strip.white = strip.white, blank.lines.skip =
>>> blank.lines.skip,
>>>       multi.line = FALSE, comment.char = comment.char, allowEscapes =
>>> allowEscapes,
>>>       flush = flush, encoding = encoding, skipNul = skipNul)
>>> 7: read.table(con, header = FALSE, sep = "|")
>>> 6: vColumns(vname)
>>> 5: nchar(as.character(vColumns(vname)$name))
>>> 4: .read_vect_non_plugin(vname = vname, layer = layer, type = type,
>>>       remove.duplicates = remove.duplicates, ignore.stderr =
>>> ignore.stderr,
>>>       pointDropZ = pointDropZ, driver = driver, with_prj = with_prj,
>>>       with_c = with_c)
>>> 3: tryCatchList(expr, classes, parentenv, handlers)
>>> 2: tryCatch({
>>>       stopifnot(is.logical(plugin) || is.null(plugin))
>>>       stopifnot(is.logical(ignore.stderr))
>>>       if (missing(layer))
>>>           layer <- 1L
>>>       layer <- as.character(layer)
>>>       stopifnot(is.logical(with_c))
>>>       if (!is.null(driver) && driver == "GRASS")
>>>           plugin <- TRUE
>>>       if (!requireNamespace("rgdal", quietly = TRUE)) {
>>>           stop("rgdal not available")
>>>       if (is.null(plugin)) {
>>>           ogrD <- rgdal::ogrDrivers()$name
>>>           plugin <- "GRASS" %in% ogrD
>>>       if (plugin) {
>>>           res <- .read_vect_plugin(vname = vname, layer = layer,
>>>               type = type, ignore.stderr = ignore.stderr, pointDropZ =
>>> pointDropZ,
>>>               mapset = mapset)
>>>       else {
>>>           res <- .read_vect_non_plugin(vname = vname, layer = layer,
>>>               type = type, remove.duplicates = remove.duplicates,
>>>               ignore.stderr = ignore.stderr, pointDropZ = pointDropZ,
>>>               driver = driver, with_prj = with_prj, with_c = with_c)
>>>   }, finally = {
>>>       if (get.suppressEchoCmdInFuncOption()) {
>>>           tull <- set.echoCmdOption(inEchoCmd)
>>> 1: readVECT(zm.gnrl)
>>>> vInfo(zm.gnrl)
>>>     nodes     points      lines boundaries  centroids      areas
>>> islands primitives      map3d
>>>       274          0          0        302         31         31
>>> 3        333          0
>>> Thanks
>>> 2015-10-09 11:36 GMT-03:00 Roger Bivand <Roger.Bivand at nhh.no>:
>>> If it is the v.info call, please run:
>>>> res <- execGRASS("v.info", flags="t", map="zm.gnrl", layer=1L,
>>>> intern=TRUE)
>>>> and report the output of:
>>>> print(res)
>>>> and maybe send me offlist the output of
>>>> save(res, file="vinfo_odd_output.RData")
>>>> Roger
>>>> Roger Bivand
>>>> Norwegian School of Economics
>>>> Helleveien 30, 5045 Bergen, Norway
>>>> ________________________________________
>>>> Fra: grass-stats [grass-stats-bounces at lists.osgeo.org] på vegne av
>>>> Roger Bivand [Roger.Bivand at nhh.no]
>>>> Sendt: 9. oktober 2015 4:27
>>>> Til: Eduardo Diez
>>>> Kopi: grass-stats at lists.osgeo.org
>>>> Emne: Re: [GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames
>>>> errors
>>>> OK, please provide the output of traceback() run immediately after the
>>>> failing readVECT(). That will show which command invokes scan(). Also try
>>>> to run vInfo(zm.gnrl) - I think the failure is in:
>>>> execGRASS("v.info", flags="t", map="zm.gnrl", layer=1L)
>>>> not returning a structure that vInfo understands, and which ois then used
>>>> in readVECT().
>>>> Roger
>>>> Roger Bivand
>>>> Fra: diez.edu at gmail.com [diez.edu at gmail.com] på vegne av Eduardo Diez [
>>>> eduardodiez at gmx.com]
>>>> Sendt: 9. oktober 2015 4:04
>>>> Til: Roger Bivand
>>>> errors
>>>> Roger, with GRASS version 7.0.1 and rgrass7_0.1-3, readVECT now doesn't
>>>> ask for the driver to use but gives the same error as before:
>>>> writeVECT(SDF = mz.pol, vname = zm.pol, v.in.ogr_flags = "o")
>>>> Over-riding projection check
>>>> Check if OGR layer <q7468fb> contains polygons...
>>>> Importing 205 features (OGR layer <q7468fb>)...
>>>> Registering primitives...
>>>> 3924 primitives registered
>>>> 12866 vertices registered
>>>> Number of nodes: 2884
>>>> Number of primitives: 3924
>>>> Number of points: 0
>>>> Number of lines: 0
>>>> Number of boundaries: 3924
>>>> Number of centroids: 0
>>>> Number of areas: -
>>>> Number of isles: -
>>>> Cleaning polygons
>>>> Breaking polygons...
>>>> Breaking polygons (pass 1: select break points)...
>>>> Breaking polygons (pass 2: break at selected points)...
>>>> Removing duplicates...
>>>> Breaking boundaries...
>>>> Cleaning boundaries at nodes...
>>>> Merging boundaries...
>>>> Removing dangles...
>>>> Building areas...
>>>> 205 areas built
>>>> 13 isles built
>>>> Number of nodes: 2929
>>>> Number of primitives: 7268
>>>> Number of points: 0
>>>> Number of lines: 0
>>>> Number of boundaries: 7268
>>>> Number of areas: 205
>>>> Number of isles: 13
>>>> Removing bridges...
>>>> 498 primitives registered
>>>> 5828 vertices registered
>>>> Building areas...
>>>> 205 areas built
>>>> 13 isles built
>>>> Attaching islands...
>>>> Number of nodes: 306
>>>> Number of primitives: 498
>>>> Number of points: 0
>>>> Number of lines: 0
>>>> Number of boundaries: 498
>>>> Number of isles: 13
>>>> Finding centroids for OGR layer <q7468fb>...
>>>> Writing centroids...
>>>> 205 input polygons
>>>> Total area: 1.25187E+006 (205 areas)
>>>> Copying features...
>>>> WARNING: Unable to delete file
>>>>  'C:/Users/ediez1/AppData/Local/Temp/Rtmpqkeay4/file480c1e5e16a7/file480c11cc233b/.tmp/unknown/vector/tmp_8308/coor'
>>>> Building topology for vector map <q7468fb at file480c11cc233b>...
>>>> 703 primitives registered
>>>> 6033 vertices registered
>>>> Building areas...
>>>> 205 areas built
>>>> 13 isles built
>>>> Attaching centroids...
>>>> Number of primitives: 703
>>>> Number of points: 0
>>>> Number of lines: 0
>>>> Number of centroids: 205
>>>> Number of isles: 13
>>>>> execGRASS("v.clean", flags = c("overwrite"), input = zm.pol,
>>>> + output = zm.gnrl, tool = "rmarea", threshold = 3000)
>>>> Tool: Threshold
>>>> Remove small areas: 3000
>>>> Copying features...
>>>> Rebuilding parts of topology...
>>>> Building topology for vector map <u10f44b at file480c11cc233b>...
>>>> Building areas...
>>>> 205 areas built
>>>> 13 isles built
>>>> Number of points: 0
>>>> Number of lines: 0
>>>> Number of isles: 13
>>>> Tool: Remove small areas
>>>> 174 areas of total size 50601.7 removed
>>>> Rebuilding topology for output vector map...
>>>> 333 primitives registered
>>>> 4705 vertices registered
>>>> Building areas...
>>>> 31 areas built
>>>> 3 isles built
>>>> Number of nodes: 274
>>>> Number of primitives: 333
>>>> Number of points: 0
>>>> Number of lines: 0
>>>> Number of boundaries: 302
>>>> Number of centroids: 31
>>>> Number of areas: 31
>>>> Number of isles: 3
>>>> na.strings,  :
>>>>> sessionInfo()
>>>> R version 3.2.2 (2015-08-14)
>>>> Platform: x86_64-w64-mingw32/x64 (64-bit)
>>>> Running under: Windows 7 x64 (build 7601) Service Pack 1
>>>> locale:
>>>> [1] LC_COLLATE=English_United States.1252  LC_CTYPE=English_United
>>>> States.1252    LC_MONETARY=English_United States.1252
>>>> [4] LC_NUMERIC=C                           LC_TIME=English_United
>>>> States.1252
>>>> attached base packages:
>>>> [1] stats     graphics  grDevices utils     datasets  methods   base
>>>> other attached packages:
>>>>  [1] RPyGeo_0.9-3    RSAGA_0.94-3    plyr_1.8.3      gstat_1.0-26
>>>> shapefiles_0.7  foreign_0.8-65  maptools_0.8-37 rgdal_1.0-7
>>>>  classInt_0.1-23
>>>> [10] raster_2.4-20   rgrass7_0.1-3   XML_3.98-1.3    sp_1.2-0
>>>> loaded via a namespace (and not attached):
>>>>  [1] Rcpp_0.12.1      intervals_0.15.1 lattice_0.20-33  FNN_1.1
>>>> spacetime_1.1-4  class_7.3-13     zoo_1.7-12       grid_3.2.2
>>>>  [9] e1071_1.6-7      xts_0.9-7        tools_3.2.2
>>>> Thanks
>>>> 2015-10-08 18:57 GMT-03:00 Roger Bivand
>>>> Sorry this has taken a long time; please try installing the development
>>>> version available from:
>>>> http://win-builder.r-project.org/8Y3Ihj451Clx
>>>> (rgrass7_0.1-3.zip). The problem was the use of "_" instead of " " in the
>>>> name of the OGR shapefile driver - in OGR and R it is "ESRI Shapefile",
>>>> in
>>>> GRASS it is "ESRI_Shapefile". Because the new long-name work-around
>>>> worked
>>>> on systems not needing to use this
>>>>  driver, it wasn't properly tested - and on Windows the GRASS standalone
>>>> has OGR with the SQLite driver, but the Windows rgdal binary does not
>>>> have
>>>> SQLite. You may wish to install the R RSQLite package to move data if you
>>>> use long field/column names.
>>>> Before installing this development version, and after library(rgrass7),
>>>> run example(readVECT) in the basic nc location from:
>>>> https://grass.osgeo.org/sampledata/north_carolina/nc_basic_spm_grass7.zip
>>>> it should fail. Then restart R, install the development version of
>>>> rgrass7
>>>> from the first link, and repeat - it works for me and should resolve the
>>>> problem.
>>>> Hope this helps,
>>>> Roger
>>>> Roger Bivand
>>>> Fra:
>>>> grass-stats-bounces at lists.osgeo.org [grass-stats-bounces at lists.osgeo.org
>>>>  på vegne av Eduardo Diez [eduardodiez at gmx.com]
>>>> Sendt: 24. september 2015 9:11
>>>> Til:
>>>> Emne: [GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames errors
>>>> Hi, I'm a user of R mostly for spatial information processing. Besides
>>>> sp,
>>>> maptools, etc. i also use functions from GRASS, at first through spgrass6
>>>> and then rgrass7. A few days ago, I started having trouble reading and
>>>> writing SpatialPolygonsDataFrames using
>>>>  readVECT and writeVECT. I tried both reinstalling both grass (6.4.4,
>>>> 7.0.0 and 7.0.1) and the R packages (spgrass6 0.8-6 and rgrass7 0.1-2),
>>>> and
>>>> also with different R objects but i kept getting the same errors.
>>>> The "mult.r" object is a RasterLayer with 4 zones and the objective is to
>>>> convert it to polygons and "clean" small areas with v.clean rmarea (as i
>>>> don't currently know a way of doing this in plain R).
>>>> The first thing that came out strange was that when executing writeVECT
>>>> it
>>>> would ask me for the driver to use (in the way of rgdal's writeOGR, it
>>>> didn't ask for it before). I figured out that object to be written should
>>>> be projected (not in lat-lon, don't know
>>>>  why). After doing this i could write the vector and execute v.clean. The
>>>> problem came again when trying to read the cleaned polygons back to R.
>>>> Below i paste an extract of my R console with the errors and some
>>>> information.
>>>> Thanks in advance,
>>>> Eduardo
>>>> mult.rp <- projectRaster(mult.r, crs = prj.crs, method = "ngb")
>>>> mult.pol <- rasterToPolygons(mult.rp, dissolve = T)
>>>> initGRASS(gisBase = "c:/Program Files (x86)/GRASS GIS 7.0.1", home =
>>>> tempdir(), override = T)
>>>> gisdbase    C:/Users/ediez1/AppData/Local/Temp/RtmpegbyiQ
>>>> location    file2f7c6dc070e6
>>>> mapset      file2f7c30eb3f52
>>>> rows        1
>>>> columns     1
>>>> north       1
>>>> south       0
>>>> west        0
>>>> east        1
>>>> nsres       1
>>>> ewres       1
>>>> projection  NA
>>>> writeVECT(mult.pol, "pol1", v.in.ogr_flags = "o")
>>>> Error: !is.null(driver) is not TRUE
>>>> writeVECT(mult.pol, "pol1", v.in.ogr_flags = "o", driver = "ESRI
>>>> Shapefile")
>>>> Check if OGR layer <r848659> contains polygons...
>>>> Importing 4 features (OGR layer <r848659>)...
>>>> 3005 primitives registered
>>>> 15587 vertices registered
>>>> Number of nodes: 2691
>>>> Number of primitives: 3005
>>>> Number of points: 0
>>>> Number of lines: 0
>>>> Number of boundaries: 3005
>>>> Number of areas: -
>>>> Number of isles: -
>>>> Cleaning polygons
>>>> Removing dangles...
>>>> Building areas...
>>>> 95 areas built
>>>> 8 isles built
>>>> Number of nodes: 2771
>>>> Number of primitives: 7307
>>>> Number of points: 0
>>>> Number of lines: 0
>>>> Number of boundaries: 7307
>>>> Number of areas: 95
>>>> Number of isles: 8
>>>> Removing bridges...
>>>> 231 primitives registered
>>>> 7594 vertices registered
>>>> Building areas...
>>>> 95 areas built
>>>> 8 isles built
>>>> Number of nodes: 144
>>>> Number of primitives: 231
>>>> Number of points: 0
>>>> Number of lines: 0
>>>> Number of boundaries: 231
>>>> Number of areas: 95
>>>> Number of isles: 8
>>>> Finding centroids for OGR layer <r848659>...
>>>> 95 input polygons
>>>> Total area: 1.28981E+006 (95 areas)
>>>> Copying features...
>>>>  'C:/Users/ediez1/AppData/Local/Temp/Rtmpg10lvi/filec2473b0126/filec24129b63ac/.tmp/unknown/vector/tmp_10484/coor'
>>>> Building topology for vector map <r848659 at filec24129b63ac>...
>>>> 326 primitives registered
>>>> 7689 vertices registered
>>>> Building areas...
>>>> 95 areas built
>>>> 8 isles built
>>>> Number of primitives: 326
>>>> Number of points: 0
>>>> Number of lines: 0
>>>> Number of centroids: 95
>>>> Number of areas: 95
>>>> Number of isles: 8
>>>> execGRASS("v.clean", flags = c("overwrite"), input = "pol1",
>>>> + output = "clnpol", tool = "rmarea", threshold = 3000)
>>>> Tool: Threshold
>>>> Copying features...
>>>> Building topology for vector map <k1f9f75 at filec24129b63ac>...
>>>> Building areas...
>>>> 95 areas built
>>>> 8 isles built
>>>> Number of points: 0
>>>> Number of lines: 0
>>>> Number of areas: 95
>>>> Number of isles: 8
>>>> 55 areas of total size 29487.1 removed
>>>> 212 primitives registered
>>>> 6840 vertices registered
>>>> Building areas...
>>>> 40 areas built
>>>> 4 isles built
>>>> Number of nodes: 136
>>>> Number of primitives: 212
>>>> Number of points: 0
>>>> Number of lines: 0
>>>> Number of boundaries: 172
>>>> Number of centroids: 40
>>>> Number of areas: 40
>>>> Number of isles: 4
>>>> cln.pol <- readVECT("clnpol")
>>>> cln.pol <- readVECT("clnpol", driver = "ESRI Shapefile")
>>>> na.strings,  :
>>>> sessionInfo()
>>>> locale:
>>>> States.1252
>>>> [1] rgrass7_0.1-2   classInt_0.1-22 maptools_0.8-36 ggplot2_1.0.1
>>>>  XML_3.98-1.3    raster_2.4-20   sp_1.2-0
>>>>  [1] Rcpp_0.12.1      magrittr_1.5     MASS_7.3-43      munsell_0.4.2
>>>> colorspace_1.2-6 lattice_0.20-33  stringr_1.0.0    plyr_1.8.3
>>>>  [9] tools_3.2.2      parallel_3.2.2   rgdal_1.0-7      grid_3.2.2
>>>>  gtable_0.1.2     e1071_1.6-7      class_7.3-13     rgeos_0.3-12
>>>> [17] digest_0.6.8     reshape2_1.4.1   labeling_0.3     stringi_0.5-5
>>>> scales_0.3.0     foreign_0.8-65   proto_0.3-10
>>>> _______________________________________________
>>>> grass-stats mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/grass-stats
>> Roger Bivand
>> Department of Economics, Norwegian School of Economics,
>> Helleveien 30, N-5045 Bergen, Norway.
>> voice: +47 55 95 93 55; fax +47 55 95 91 00
>> e-mail: Roger.Bivand at nhh.no
Roger Bivand
More information about the grass-stats mailing list
