[GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames errors
Roger Bivand
Roger.Bivand at nhh.no
Sun Oct 11 07:28:35 PDT 2015
On Sat, 10 Oct 2015, Roger Bivand wrote:
> On Sat, 10 Oct 2015, Eduardo Diez wrote:
>> This is what i got:
>>> vinfo0 <- execGRASS("v.info", flags="c", map=zm.gnrl)INTEGER|cat
>> INTEGER|ID
>> INTEGER|GRIDCODE
>> Displaying column types/names for database connection of layer <1>:
>> And trying to read back the original polygon (without v.clean):
>>> zm.fnl <- readVECT(zm.pol)Error in scan(file, what, nmax, sep, dec, quote,
> skip, nlines, na.strings, :
>> line 4 did not have 2 elements
> This is coming from:
> G_message(_("Displaying column types/names for database connection of
> layer <%s>:"), field_opt);
> line 134 in vector/v.info/print.c.
> For me in nc_basic, for schools, I do not see the message with:
> vinfo0 <- execGRASS("v.info", flags="c", map="schools", layer="1",
> intern=TRUE)
> which is what is being used in vColumns. Is there an alternative to v.info
> that may be less error-prone?
The development Windows binary of rgrass7 at:
http://win-builder.r-project.org/9YK08bQi1ldt
is an attempt to address a problem I cannot reproduce (with GRASS 7.0.1
Windows standalone) - instead of assuming two-column output, it drops
lines with != 2 columns and issues a warning if they were found.
There is a further weakness in the readVECT code involving a conditional
assumption that the db driver is sqlite - is there any way to check from
outside which driver is being used?
Roger
> Roger
>> 2015-10-10 13:12 GMT-03:00 Roger Bivand <Roger.Bivand at nhh.no>:
>>> Apparently "v.info" through execGRASS is expecting the "layer" argument to
>>>> be a string rather than an integer.
>>> Yes, please re-run with "1"; this resulted from GRASS6 to GRASS7
>>> over-enthusiastic changing everything just for fun - this isn't the
>>> problem. Run (assuming that zm.gnrl contains a character string):
>>> My guess is that v.info is saying that this map is broken, or suffering
>>> from something that vColumns does not know about.
>>> v.info -c map=
>>> should simply respond with "<storage type>|<name>" lines for the fields in
>>> the layer. Here, its fourth line (unlike the first three) does not have
> two
>>> elements (the type/name pairs).
>>> Does readVECT() work if you do not use v.clean? Is v.clean having a side
>>> effect of causing v.info -c to "say" something else? How should the input
>>> columns of the object to be cleaned be turned into output columns (simply
>>> copy across the retained areas?)?
>>> Roger
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
