[GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames errors
Markus Neteler neteler at osgeo.org
Sun Oct 11 09:23:34 PDT 2015
On Sun, Oct 11, 2015 at 4:28 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> There is a further weakness in the readVECT code involving a conditional
> assumption that the db driver is sqlite - is there any way to check from
> outside which driver is being used?
db.connect - Prints/sets general DB connection for current mapset.
It reads/stores the information in the file
<location>/<mapset>/VAR
which is a parsable ASCII file, using the variables
DB_DRIVER
DB_DATABASE
Best
Markus
More information about the grass-stats mailing list
