[GRASS-stats] raster data in R
Markus Neteler
neteler at osgeo.org
Thu Sep 10 07:47:28 PDT 2015
Hi Rainer,
On Thu, Sep 10, 2015 at 4:36 PM, Rainer M Krug <Rainer at krugs.de> wrote:
> Just check out the rgrass7 package - readRAST() allows you to read your
> raster, then you do your calculations with the data,
... this calculation part is the question of Marisa... any recommended
tutorials on how to loop over pixels in R after having used
readRAST()?
> then you add them
> to the map object in R and finally you can safe them by using
> writeRAST() back to GRASS.
Yes, that part is clear. Just the "loop" best practice not so much.
thanks
Markus
More information about the grass-stats
