[GRASS-stats] raster data in R
Rainer M Krug
Rainer at krugs.de
Thu Sep 10 07:36:51 PDT 2015
Marisa Donnelly <madonnelly at ucdavis.edu> writes:
> Hello,
> I am currently working on a project attempts to summarize the potential
> mosquito reproductive rate of regions in California given the region's mean
> annual daily temperature. I have a written a model in R that uses
> temperature as an input and outputs the reproductive rate given that
> temperature. I have also constructed a raster map in GRASS GIS version 7.1
> of the aggregated California daily tmean values for a year. I would like to
> take the tmean temperature value of each pixel in the California map, input
> it into my model in R, and generate a reproductive rate for each pixel,
> which I would then like to be able to map. I would like to find the best
> and most efficient way to bring in the map data into R and input it into my
> model. Do you any suggestions for the best way to do this?
I assume that you are accustomed to using R.
Just check out the rgrass7 package - readRAST() allows you to read your
raster, then you do your calculations with the data, then you add them
to the map object in R and finally you can safe them by using
writeRAST() back to GRASS.
Cheers,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150910/7d3b24f1/attachment.pgp>
More information about the grass-stats
