[GRASS-stats] R in GRASS - v.db.addcolumn Error
Roger Bivand
Roger.Bivand at nhh.no
Sat May 7 11:50:04 PDT 2016
On Sat, 7 May 2016, Maximilian Bakenhus wrote:
> Okay it seems nabble really ate my content,
> this is the code and my grass version
> System Info
No, the output of sessionInfo() is essential, unless you know that you are
running rgrass7 version 0.1-7, if not, update.
You have:
> execGRASS("v.db.addcolumn", parameters = list(map = "sites_3", columns =
> "dist double precision, cats integer, xm double precision, ym double
> precision"))
> # hat den Befehl nicht gefunden, ausführung über GUI in GRASS über
> Befehlssuche
and
> parameters = list(map = paste0('ws_', take at data$site_id),
> columns = "area_sqkm double"))
columns= must be a character vector; perhaps:
columns=c("dist double precision", "cats integer", "xm double precision",
"ym double precision")
This should be fairly obvious.
Roger
> GRASS version: 7.0.3
> GRASS SVN Revision: 67691
> Build Date: 2016-01-10
> Build Platform: x86_64-w64-mingw32
> GDAL/OGR: 1.11.3
> PROJ.4: 4.9.2
> GEOS: 3.5.0
> SQLite: 3.7.17
> Python: 2.7.5
> wxPython: 2.8.12.1
> Platform: Windows-8-6.2.9200
> # Initialize GRASS
> loc <- initGRASS(gisBase = "C:/GRASS GIS 7.0.3",
> home = tempdir(),
> gisDbase = 'C:/Users/KingGoerge/Documents/GIS DataBase 2',
> location = 'usa',
> mapset = 'kansas-4', override = TRUE )
> loc
> # perhabs first create loaction and map before in GUI?
> # # # read DEM
> execGRASS("r.in.gdal", flags = c("overwrite", "o"),
> parameters = list(input = 'C:/Users/KingGoerge/Documents/Gis
> Projekte/GIS Advanced
> Projekt/Höhenmodell-Kansas/20160429133734_122375530.tif',
> output = "DEM"))
> execGRASS("g.list", parameters = list(type = "rast"))
> # set region
> execGRASS("g.region", parameters = list(raster = 'DEM'))
> gmeta()
> # # extract flow direction + streams from dem:
> execGRASS("r.watershed", flags = "overwrite",
> parameters = list(elevation = "DEM",
> drainage = 'fdir', # save flow direction as
> raster named "fdir"
> stream = 'stream', # save derived streams as
> raster named "stream"
> threshold = 750))
> # list all rasters available in GRASS-Session
> # now with fdir and stream
> # thin streams and convert to line and clean
> # thin = make stream 1pixel width
> execGRASS("r.thin", flags = "overwrite", parameters = list(input =
> 'stream', output = 'stream_t'))
> # convert to line vector
> execGRASS("r.to.vect", flags = "overwrite", parameters = list(input =
> 'stream_t', output = 'streams', type = 'line' ))
> # clean vector (see help for more information)
> execGRASS("v.clean", flags = c("overwrite", "c"), parameters = list(input
> = 'streams', output = 'streams_c', tool = 'break'))
> # read sampling sites
> sites3 <- read.table('C:/Users/KingGoerge/Documents/Gis Projekte/GIS
> Advanced Projekt/Messpunkte_Kansas-formatiert.csv', header = TRUE, sep =
> # set coordinates to create a spatial R object
> coordinates(sites3) <- ~longitude + latitude
> plot(sites3)
> # write to GRASS
> writeVECT(sites3, "sites_3", v.in.ogr_flags = c("o", "overwrite"))
> # list all vectors
> execGRASS("g.list", parameters = list(type = "vect"))
> ## snap sites to streams
> # add columns to attributed table of sites
> # for distance id and coordinates of nearest streams,
> precision"))
> Befehlssuche
> # calc distance of points to nearest stream
> # and save distance and new coordinates to newly created columns
> execGRASS("v.distance", flags = c("overwrite"),
> parameters = list(from = 'sites_2',
> to = 'streams_c',
> output = 'connectors',
> upload = 'dist,cat,to_x,to_y',
> column = 'dist,cats,xm,ym'))
> # extract new points (=snapped coordinates)
> # save to disc
> execGRASS("v.db.select", flags = c('c', 'overwrite'),
> parameters = list(map = 'sites_2',
> columns = c('xm,ym'),
> file = 'C:/Users/KingGoerge/Documents/Gis
> Projekte/GIS Advanced Projekt/new_points_kansas.txt'))
> # load from disc
> execGRASS("v.in.ascii", flags = c("overwrite"),
> Projekte/GIS Advanced Projekt//new_points_kansas.txt',
> output = "new_sites"))
> ### Calculate catchments
> # read new sites
> snapped <- readVECT('new_sites')
> # copy sites_id from table to vectordata
> snapped at data$site_id <- sites$site_id
> # for each Point in snapped...
> for (i in seq_len(nrow(snapped))) {
> # extract respective point
> take <- snapped[i,]
> message(paste0(i, ' out of ', nrow(snapped)))
> # calculate drainage area
> execGRASS("r.water.outlet", flags = 'overwrite',
> parameters = list(input = 'fdir', # flow direction as input
> output = paste0('da_', take at data$site_id), #
> save as raster named "da_<site_id>" (da = drainage area)
> coordinates = coordinates(take)[ ,1:2])) #
> coordinates of point for which drainage should be calculated
> # execGRASS("g.list", parameters = list(type = "rast"))
> # make raster to vector
> execGRASS("r.to.vect", flags = 'overwrite',
> parameters = list(input = paste0('da_', take at data$site_id), #
> input = "da_<site_id>" (=raster)
> output = paste0('ws_', take at data$site_id), #
> output = "ws_<site_id>" (=vector polygon)
> type = 'area'))
> # execGRASS("g.list", parameters = list(type = "vect"))
> # Add a column 'area_sqkm' for area in sq.km to attributed table
> # calculate aresa and save to "area_sqkm" column
> execGRASS("v.to.db", parameters = list(
> option = 'area',
> columns = 'area_sqkm', units = 'kilometers'))
> 2016-05-06 22:11 GMT+02:00 Roger Bivand <Roger.Bivand at nhh.no>:
>> You have still not stated your rgrass7 version. This really is important,
>> without knowing this no help is possible. You must give much more detail of
>> what you are actually doing; make sure that rstudio is not getting in the
>> way (it runs R in separate sessions).
>> * DO NOT POST IN NABBLE, IT CAN EAT CONTENT*
>> Roger
>> On Fri, 6 May 2016, Maximilian Bakenhus wrote:
>> Hello Community,
>>> I am a german student and I work with some other students at a GRASS
>>> Project,
>>> its about watershed modeling of a DEM Projection and snap measuring points
>>> over the new streams.
>>> We do this with the newest version of R Studio and GRASS 7.0.3
>>> This here is part of our code:
>> Where???
>>> As we try do do the last order,
>>> the* v.db.addcolumn*, we retrieve this error:
>>> *Error in system(cmd0, intern = TRUE) : 'v.db.addcolumn.exe' not found
>>> Error in parseGRASS(cmd, legacyExec = legacyExec) :
>>> v.db.addcolumn not found*
>>> We really dont know, how to fix it and hope someone here does, cause we
>>> need
>>> it very urgent.
>>> Thanks for reading,
>>> have a nice day
>>> Max
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/R-in-GRASS-v-db-addcolumn-Error-tp5265014.html
>>> Sent from the Grass - Stats mailing list archive at Nabble.com.
>>> grass-stats mailing list
>>> grass-stats at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-stats
>> Roger Bivand
>> Department of Economics, Norwegian School of Economics,
>> Helleveien 30, N-5045 Bergen, Norway.
>> voice: +47 55 95 93 55; fax +47 55 95 91 00
>> e-mail: Roger.Bivand at nhh.no
>> http://orcid.org/0000-0003-2392-6140
>> https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
>> http://depsy.org/person/434412
Roger Bivand
More information about the grass-stats
