[GRASS-stats] R in GRASS - v.db.addcolumn Error
Maximilian Bakenhus
maximilianbakenhus at gmail.com
Sat May 7 03:49:29 PDT 2016
Okay it seems nabble really ate my content,
this is the code and my grass version
System Info
GRASS version: 7.0.3
GRASS SVN Revision: 67691
Build Date: 2016-01-10
Build Platform: x86_64-w64-mingw32
GDAL/OGR: 1.11.3
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200
# Initialize GRASS
loc <- initGRASS(gisBase = "C:/GRASS GIS 7.0.3",
home = tempdir(),
gisDbase = 'C:/Users/KingGoerge/Documents/GIS DataBase 2',
location = 'usa',
mapset = 'kansas-4', override = TRUE )
loc
# perhabs first create loaction and map before in GUI?
# # # read DEM
execGRASS("r.in.gdal", flags = c("overwrite", "o"),
parameters = list(input = 'C:/Users/KingGoerge/Documents/Gis
Projekte/GIS Advanced
Projekt/Höhenmodell-Kansas/20160429133734_122375530.tif',
output = "DEM"))
execGRASS("g.list", parameters = list(type = "rast"))
# set region
execGRASS("g.region", parameters = list(raster = 'DEM'))
gmeta()
# # extract flow direction + streams from dem:
execGRASS("r.watershed", flags = "overwrite",
parameters = list(elevation = "DEM",
drainage = 'fdir', # save flow direction as
raster named "fdir"
stream = 'stream', # save derived streams as
raster named "stream"
threshold = 750))
# list all rasters available in GRASS-Session
# now with fdir and stream
# thin streams and convert to line and clean
# thin = make stream 1pixel width
execGRASS("r.thin", flags = "overwrite", parameters = list(input =
'stream', output = 'stream_t'))
# convert to line vector
execGRASS("r.to.vect", flags = "overwrite", parameters = list(input =
'stream_t', output = 'streams', type = 'line' ))
# clean vector (see help for more information)
execGRASS("v.clean", flags = c("overwrite", "c"), parameters = list(input
= 'streams', output = 'streams_c', tool = 'break'))
# read sampling sites
sites3 <- read.table('C:/Users/KingGoerge/Documents/Gis Projekte/GIS
Advanced Projekt/Messpunkte_Kansas-formatiert.csv', header = TRUE, sep =
# set coordinates to create a spatial R object
coordinates(sites3) <- ~longitude + latitude
plot(sites3)
# write to GRASS
writeVECT(sites3, "sites_3", v.in.ogr_flags = c("o", "overwrite"))
# list all vectors
execGRASS("g.list", parameters = list(type = "vect"))
## snap sites to streams
# add columns to attributed table of sites
# for distance id and coordinates of nearest streams,
execGRASS("v.db.addcolumn", parameters = list(map = "sites_3", columns =
"dist double precision, cats integer, xm double precision, ym double
precision"))
# hat den Befehl nicht gefunden, ausführung über GUI in GRASS über
Befehlssuche
# calc distance of points to nearest stream
# and save distance and new coordinates to newly created columns
execGRASS("v.distance", flags = c("overwrite"),
parameters = list(from = 'sites_2',
to = 'streams_c',
output = 'connectors',
upload = 'dist,cat,to_x,to_y',
column = 'dist,cats,xm,ym'))
# extract new points (=snapped coordinates)
# save to disc
execGRASS("v.db.select", flags = c('c', 'overwrite'),
parameters = list(map = 'sites_2',
columns = c('xm,ym'),
file = 'C:/Users/KingGoerge/Documents/Gis
Projekte/GIS Advanced Projekt/new_points_kansas.txt'))
# load from disc
execGRASS("v.in.ascii", flags = c("overwrite"),
Projekte/GIS Advanced Projekt//new_points_kansas.txt',
output = "new_sites"))
### Calculate catchments
# read new sites
snapped <- readVECT('new_sites')
# copy sites_id from table to vectordata
snapped at data$site_id <- sites$site_id
# for each Point in snapped...
for (i in seq_len(nrow(snapped))) {
# extract respective point
take <- snapped[i,]
message(paste0(i, ' out of ', nrow(snapped)))
# calculate drainage area
execGRASS("r.water.outlet", flags = 'overwrite',
parameters = list(input = 'fdir', # flow direction as input
output = paste0('da_', take at data$site_id), #
save as raster named "da_<site_id>" (da = drainage area)
coordinates = coordinates(take)[ ,1:2])) #
coordinates of point for which drainage should be calculated
# execGRASS("g.list", parameters = list(type = "rast"))
# make raster to vector
execGRASS("r.to.vect", flags = 'overwrite',
parameters = list(input = paste0('da_', take at data$site_id), #
input = "da_<site_id>" (=raster)
output = paste0('ws_', take at data$site_id), #
output = "ws_<site_id>" (=vector polygon)
type = 'area'))
# execGRASS("g.list", parameters = list(type = "vect"))
# Add a column 'area_sqkm' for area in sq.km to attributed table
parameters = list(map = paste0('ws_', take at data$site_id),
columns = "area_sqkm double"))
# calculate aresa and save to "area_sqkm" column
execGRASS("v.to.db", parameters = list(
option = 'area',
columns = 'area_sqkm', units = 'kilometers'))
2016-05-06 22:11 GMT+02:00 Roger Bivand <Roger.Bivand at nhh.no>:
> You have still not stated your rgrass7 version. This really is important,
> without knowing this no help is possible. You must give much more detail of
> what you are actually doing; make sure that rstudio is not getting in the
> way (it runs R in separate sessions).
> * DO NOT POST IN NABBLE, IT CAN EAT CONTENT*
> Roger
> On Fri, 6 May 2016, Maximilian Bakenhus wrote:
> Hello Community,
>> I am a german student and I work with some other students at a GRASS
>> Project,
>> its about watershed modeling of a DEM Projection and snap measuring points
>> over the new streams.
>> We do this with the newest version of R Studio and GRASS 7.0.3
>> This here is part of our code:
> Where???
>> As we try do do the last order,
>> the* v.db.addcolumn*, we retrieve this error:
>> *Error in system(cmd0, intern = TRUE) : 'v.db.addcolumn.exe' not found
>> Error in parseGRASS(cmd, legacyExec = legacyExec) :
>> v.db.addcolumn not found*
>> We really dont know, how to fix it and hope someone here does, cause we
>> need
>> it very urgent.
>> Thanks for reading,
>> have a nice day
>> Max
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/R-in-GRASS-v-db-addcolumn-Error-tp5265014.html
>> Sent from the Grass - Stats mailing list archive at Nabble.com.
>> grass-stats mailing list
>> grass-stats at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
> Roger Bivand
> Department of Economics, Norwegian School of Economics,
> Helleveien 30, N-5045 Bergen, Norway.
> voice: +47 55 95 93 55; fax +47 55 95 91 00
> e-mail: Roger.Bivand at nhh.no
> http://orcid.org/0000-0003-2392-6140
> https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
> http://depsy.org/person/434412
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20160507/254c5e41/attachment-0001.html>
More information about the grass-stats
