[GRASS-stats] rgrass7 is not loading
Norbert Zirps
Norbert.Zirps at web.de
Mon Sep 19 11:38:26 PDT 2016
Dear grass users,
since today I’ve the following problem:
starting rgrass7 package in R in the grass7 console I get the following error message:
> library(rgrass7)
Lade n├Âtiges Paket: sp
Lade n├Âtiges Paket: XML
Error : .onAttach in attachNamespace() f├╝r 'rgrass7' fehlgeschlagen, Details:
Aufruf: if (class(t0) != "try-error" && is.character(t0) && nchar(t0) >
Fehler: Fehlender Wert, wo TRUE/FALSE n├Âtig ist
Fehler: Laden von Paket oder Namensraum f├╝r 'rgrass7' fehlgeschlagen
I tried the following options:
New installation of GRASS7 and R
Updated all packages in R
Installed the package rgrass7 on both sides, in an single R Session and also in the R Session inside the GRASS console,
But nothing works.
Is it possible to fix this?
Is there a way to set the namespaces for R or to repair them?
By the way: The same problem seems to be at v.krige in the GUI. I never get this addon to work and need to use the kriging interpolation methods.
Thank you for your help,
kind regards, Norbert Zirps.
Norbert Zirps
Reichenstraße 14
02625 Bautzen
mobil 015774938930
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20160919/9b9a0660/attachment.html>
More information about the grass-stats
