[GRASS-stats] R and GRASS on Windows - Status 1
M Bakenhus
maximilianbakenhus at gmail.com
Thu Nov 9 13:15:23 PST 2017
> you have to keep it on the mailing list, otherwise no one is able to
> answer.
True, thanks for recognizing.
Furthermore, the OS used is Windows 10 Pro.
I argued if its maybe because of missing writing privileges,
but I don't know how to check that.
2017-11-09 22:07 GMT+01:00 Helmut Kudrnovsky <hellik at web.de>:
> (1)‘3.4.2’of R, Version 1.1.383 of R Studio
> (2) GRASS Standalone
> (3)
> a <- NULL
> for(i in 1:length(anames)){
> print(anames[i])
> a <- c(a,unique(execGRASS("v.db.select",
> parameters = list(
> map = anames[i],
> columns = "objart"
> ), intern = T)[-1]))
> Warning messages:
> 1: running command 'v.db.select.exe map=veg_01_sa_31467.shp columns=objart'
> had status 1
> For any GRASS related command I get a similar error.
> answer.
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Stats-f4049448.html
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-stats
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20171109/51477e56/attachment.html>
More information about the grass-stats
