[GRASS-stats] R and GRASS on Windows - Status 1
    Roger Bivand
    Roger.Bivand at nhh.no
    Thu Nov  9 13:22:16 PST 2017
On Thu, 9 Nov 2017, M Bakenhus wrote:
>> you have to keep it on the mailing list, otherwise no one is able to
>> answer.
> True, thanks for recognizing.
> Furthermore, the OS used is Windows 10 Pro.
> I argued if its maybe because of missing writing privileges,
> but I don't know how to check that.
Just speculation, really.
Make a completely reproducible example with the North Carolina location. I
guess (but without such an example cannot check) that at least one of the
parameters is wrongly set.
Almost certainly you must simplify first, then find the corner cases
needing special treatment.
> 2017-11-09 22:07 GMT+01:00 Helmut Kudrnovsky <hellik at web.de>:
>> (1)‘3.4.2’of R, Version 1.1.383   of R Studio
>> (2) GRASS Standalone
>> (3)
>> a <- NULL
>> for(i in 1:length(anames)){
>>   print(anames[i])
>>   a <- c(a,unique(execGRASS("v.db.select",
>>                             parameters = list(
>>                               map = anames[i],
>>                               columns = "objart"
>>                             ), intern = T)[-1]))
>> Warning messages:
>> 1: running command 'v.db.select.exe map=veg_01_sa_31467.shp columns=objart'
>> had status 1
>> For any GRASS related command I get a similar error.
>> answer.
>> best regards
>> Helmut
>> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Stats-f4049448.html
>> grass-stats mailing list
>> grass-stats at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
Editor-in-Chief of The R Journal, https://journal.r-project.org/index.html
http://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
More information about the grass-stats
