[GRASS-stats] Error when starting grass from R (grass installed thru osgeo4w)
Veronica Andreo
veroandreo at gmail.com
Sun Sep 16 08:04:45 PDT 2018
Perfect, will test and report back in case of any issue.
Thanks, Helli :)
El dom., 16 sept. 2018 a las 17:00, Helmut Kudrnovsky (<hellik at web.de>)
escribió:
> >Should I open R from OSGeo4W command console and then init grass there? Is
> that the workflow?
> Yes, that's the workflow.
> because environment variables for e.g. gdal, proj4 etc have to be set. And
> that's nicely done in the OSGeo4W command line
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Stats-f4049448.html
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-stats
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20180916/7478076f/attachment.html>
More information about the grass-stats
