[GRASS-stats] Error when starting grass from R (grass installed thru osgeo4w)
Helmut Kudrnovsky
hellik at web.de
Sun Sep 16 08:00:14 PDT 2018
>Should I open R from OSGeo4W command console and then init grass there? Is
that the workflow?
Yes, that's the workflow.
because environment variables for e.g. gdal, proj4 etc have to be set. And
that's nicely done in the OSGeo4W command line
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Stats-f4049448.html
More information about the grass-stats
