[GRASS-stats] Error when starting grass from R (grass installed thru osgeo4w)
Veronica Andreo
veroandreo at gmail.com
Mon Sep 24 15:53:39 PDT 2018
Hi Roger,
> It should work even in a directory without write permission - now it tests
> first rather than failing. Probably the default should be to use a
> temporary file for GISRC anyway, but ten years ago that seemed
> challenging.
> >> I also corrected the PROJ shared files location for GRASS (I hope). I
> can
> >> provide a Windows binary package
> >> off-list if need be.
> > How to find/test for the location of PROJ shared files?
> You don't need to, it's just to do with correcting a carry-over from file
> organization in GRASS 6 that had not been correct for GRASS 7 when
> setting up environment variables for GRASS.
> >> Please let me know if this gets things working.
> >> I'm also concerned to know how rgrass7 should be maintained going
> forward?
> >> Should it be on github/r-spatial ? Should it migrate to sf/raster
> classes?
> > IMHO, moving to sf/raster classes seems reasonable. However, if it is too
> > much of a hassle or there's no consensus, going from sp to sf is just one
> > line in R once a GRASS vector has been read in and, for the raster data,
> as
> > well.
> I already have a trial sf/raster github repo, but the recent edits are not
> present there. It only uses sf for vector, but is stuck with sp/raster for
> raster, so was waiting for stars or similar to provide something newer.
star given :)
Didn't know about this repo. I think github/r-spatial is also probably the
better place to hold the official rgrass7 in the (near?) future
Cheers,
Vero
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20180925/bbc2f234/attachment.html>
More information about the grass-stats
