[GRASS-stats] Error when starting grass from R (grass installed thru osgeo4w)
    Roger Bivand
    Roger.Bivand at nhh.no
    Tue Sep 25 01:40:33 PDT 2018
On Tue, 25 Sep 2018, Veronica Andreo wrote:
> Hi Roger,
>> It should work even in a directory without write permission - now it tests
>> first rather than failing. Probably the default should be to use a
>> temporary file for GISRC anyway, but ten years ago that seemed
>> challenging.
>>>> I also corrected the PROJ shared files location for GRASS (I hope). I
>> can
>>>> provide a Windows binary package
>>>> off-list if need be.
>>> How to find/test for the location of PROJ shared files?
>> You don't need to, it's just to do with correcting a carry-over from file
>> organization in GRASS 6 that had not been correct for GRASS 7 when
>> setting up environment variables for GRASS.
>>>> Please let me know if this gets things working.
>>>> I'm also concerned to know how rgrass7 should be maintained going
>> forward?
>>>> Should it be on github/r-spatial ? Should it migrate to sf/raster
>> classes?
>>> IMHO, moving to sf/raster classes seems reasonable. However, if it is too
>>> much of a hassle or there's no consensus, going from sp to sf is just one
>>> line in R once a GRASS vector has been read in and, for the raster data,
>> as
>>> well.
>> I already have a trial sf/raster github repo, but the recent edits are not
>> present there. It only uses sf for vector, but is stuck with sp/raster for
>> raster, so was waiting for stars or similar to provide something newer.
> star given :)
> Didn't know about this repo. I think github/r-spatial is also probably the
> better place to hold the official rgrass7 in the (near?) future
Yes, but until we know whether getClass("Raster") in the raster Package is
a stable target match for GRASS raster layers (as sp::SpatialGridDataFrame
has been), we don't know how to drop the sp dependency. raster still
depends on sp and suggests rgdal; it now also suggests sf, so maybe in a
little while an R/GRASS interface could be just sf/rgdal-based. To support
existing workflows, a legacy mode would be needed, I think. So rgrass7
would load in legacy mode, but pivot to sf/raster if legacy mode was set
FALSE? The r-spatial/stars project is making some progress as Edzer
described in Pruchonice, but is split between local arrays and/or
cloud-based representations. When stars reaches a sweet spot, rgrass7 can
follow it for the R-side representation.
Best wishes,
Roger
> Cheers,
> Vero
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
http://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
More information about the grass-stats
