[GRASS-stats] Error when starting grass from R (grass installed thru osgeo4w)
Roger Bivand
Roger.Bivand at nhh.no
Fri Sep 28 01:25:02 PDT 2018
Package rgrass7_0.1-12.tar.gz is on its way to CRAN, with work-around for
OSGeo4W no write access console startup directory.
Roger
On Tue, 25 Sep 2018, Roger Bivand wrote:
> On Tue, 25 Sep 2018, Veronica Andreo wrote:
>> Hi Roger,
>>> It should work even in a directory without write permission - now it
>>> tests
>>> first rather than failing. Probably the default should be to use a
>>> temporary file for GISRC anyway, but ten years ago that seemed
>>> challenging.
>>>>> I also corrected the PROJ shared files location for GRASS (I hope). I
>>> can
>>>>> provide a Windows binary package
>>>>> off-list if need be.
>>>> How to find/test for the location of PROJ shared files?
>>> You don't need to, it's just to do with correcting a carry-over from file
>>> organization in GRASS 6 that had not been correct for GRASS 7 when
>>> setting up environment variables for GRASS.
>>>>> Please let me know if this gets things working.
>>>>> I'm also concerned to know how rgrass7 should be maintained going
>>> forward?
>>>>> Should it be on github/r-spatial ? Should it migrate to sf/raster
>>> classes?
>>>> IMHO, moving to sf/raster classes seems reasonable. However, if it is
>>>> too
>>>> much of a hassle or there's no consensus, going from sp to sf is just
>>>> one
>>>> line in R once a GRASS vector has been read in and, for the raster data,
>>> as
>>>> well.
>>> I already have a trial sf/raster github repo, but the recent edits are
>>> not
>>> present there. It only uses sf for vector, but is stuck with sp/raster
>>> for
>>> raster, so was waiting for stars or similar to provide something newer.
>> star given :)
>> Didn't know about this repo. I think github/r-spatial is also probably the
>> better place to hold the official rgrass7 in the (near?) future
> Yes, but until we know whether getClass("Raster") in the raster Package is a
> stable target match for GRASS raster layers (as sp::SpatialGridDataFrame has
> been), we don't know how to drop the sp dependency. raster still depends on
> sp and suggests rgdal; it now also suggests sf, so maybe in a little while an
> R/GRASS interface could be just sf/rgdal-based. To support existing
> workflows, a legacy mode would be needed, I think. So rgrass7 would load in
> legacy mode, but pivot to sf/raster if legacy mode was set FALSE? The
> r-spatial/stars project is making some progress as Edzer described in
> Pruchonice, but is split between local arrays and/or cloud-based
> representations. When stars reaches a sweet spot, rgrass7 can follow it for
> the R-side representation.
> Best wishes,
> Roger
>> Cheers,
>> Vero
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
http://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
More information about the grass-stats
