[GRASS-stats] Error when starting grass from R (grass installed thru osgeo4w)
Veronica Andreo veroandreo at gmail.com
Sun Sep 16 07:42:43 PDT 2018
Hi Helli, Roger
No, I just opened R console (installed outside OSGeo4W) and from there, I
tried to init grass.
Should I open R from OSGeo4W command console and then init grass there? Is
that the workflow?
best,
Vero
El dom., 16 sept. 2018 a las 16:25, Helmut Kudrnovsky (<hellik at web.de>)
escribió:
> Veronica Andreo wrote
> > Hello,
> > I am preparing a one week GRASS GIS course and I mostly expect Windows
> > users, so I recommend to install from OSGeo4W that allows to easily
> > install
> > also QGIS, msys (to get nice bash tricks) and other libraries that are
> > then
> > needed for some grass add-ons.
> > The last day of the course, I'll show the connection with R. Now,
> starting
> > R within a grass session works as expected. But I get errors when trying
> > to
> > initialize GRASS (installed from OSGeo4W) from R console. I am following
> > the instructions in the wiki [0]
> > First, I had to change the slashes from windows type, to linux type
> > (because I got:
> > Error: '\O' in an unrecognized escape in character string ""C:\O").
> > After that, I get the following:
> >> initGRASS(gisBase = 'C:/OSGeo4W64/apps/grass/grass-7.4.0', gisDbase =
> > 'C:/Users/RETA/Documents/grassdata', location = 'nc_spm_08_grass7',
> mapset
> > = 'user1', SG='elevation')
> > Error in if (!compatible) { : argumento tiene longitud cero
> > Además: Warning messages:
> > 1: In system(paste("g.dirseps.exe -g", shQuote(Sys.getenv("GISRC"))), :
> > comando ejecutado 'g.dirseps.exe -g "junk"' tiene estatus 309
> > 2: In system(paste("g.dirseps.exe -g", shQuote(gisDbase)), intern = TRUE)
> > comando ejecutado 'g.dirseps.exe -g "C:/Users/RETA/Documents/grassdata"'
> > tiene estatus 309
> > 3: In dir.create(loc_path) :
> > cannot create dir 'NA\nc_spm_08_grass7', reason 'No such file or
> > directory'
> > 4: In dir.create(paste(loc_path, "PERMANENT", sep = "/")) :
> > cannot create dir 'NA\nc_spm_08_grass7\PERMANENT', reason 'No such file
> or
> > directory'
> > 5: In dir.create(paste(loc_path, mapset, sep = "/")) :
> > cannot create dir 'NA\nc_spm_08_grass7\user1', reason 'No such file or
> > directory'
> > 6: In system(paste("g.version", get("addEXE", envir = .GRASS_CACHE), :
> > comando ejecutado 'g.version.exe' tiene estatus 309
> > Any hints? I also attach a screenshot with the message that appears (I
> > cannot copy/paste the text in that message)
> > Thanks much in advance!
> > Vero
> > [0] https://grasswiki.osgeo.org/wiki/R_statistics/rgrass7#GRASS_within_R
> > grass-stats mailing list
> > grass-stats at .osgeo
> > https://lists.osgeo.org/mailman/listinfo/grass-stats
> > Rgui_2018-09-13_22-19-45.png (73K)
> http://osgeo-org.1560.x6.nabble.com/attachment/5378245/0/Rgui_2018-09-13_22-19-45.png&gt
> it's a missing dll.
> Are you invoking R from inside the OSGeo4W command console?
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Stats-f4049448.html
> grass-stats at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20180916/380cce01/attachment-0001.html>
More information about the grass-stats mailing list
