[GRASS-stats] Issue with grass initialization with rgrass 0.4-2
Roger Bivand Roger.Bivand at nhh.no
Fri Jun 7 03:55:32 PDT 2024
Améline's message here is to solicit input from others, and may be followed up here and/or at https://github.com/rsbivand/rgrass/issues/88
Roger
Roger Bivand
Emeritus Professor
Norwegian School of Economics
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
________________________________________
From: grass-stats <grass-stats-bounces at lists.osgeo.org> on behalf of Améline Vallet via grass-stats <grass-stats at lists.osgeo.org>
Sent: 07 June 2024 11:03
To: grass-stats at lists.osgeo.org
Subject: [GRASS-stats] Issue with grass initialization with rgrass 0.4-2
Dear all,
Since I updated GRASS (8.2 -> 8.3.2) and rgrass (?-> 0.4-2), the
installation seems broken and I can't start a GRASS session from R
anymore. The error message I receive is the following:
Error in read_xml.raw(charToRaw(enc2utf8(x)), "UTF-8", ..., as_html =
as_html,  :
   Premature end of data in tag guisection line 1 [77]
De plus : Message d'avis :
Dans readLines(outFile) :
   ligne finale incomplète trouvée dans '/tmp/Rtmp9qeL4f/file36b3e2cdcc8ad'
Erreur dans parseGRASS(cmd, legacyExec = legacyExec) : g.region not parsed
Here below an example which I hope is reproducible:
Sys.setenv("GRASS_INSTALLATION"="/usr/lib/grass83")
library(rgrass)
library(unixtools)
set.tempdir("/my_path/temporary_files")
GRASS_INSTALLATION <- Sys.getenv("GRASS_INSTALLATION")
loc <- initGRASS(gisBase=GRASS_INSTALLATION, home=tempdir(), SG=r,
override=TRUE, remove_GISRC = TRUE) #return error message
loc2 <- initGRASS() #return error message
I receive the same error message whether I use a custom path for temp
files or not, and when I manually indicate within the initGRASS function
custom entry parameters.
We are using GRASS 8.3.2 and R version 4.4.0 in a linux environment
(Ubuntu 22.04.4 LTS). GRASS works well (I can use all applications from
a GRASS session started in the terminal).
print(version)
platform       x86_64-pc-linux-gnu
arch           x86_64
os             linux-gnu
system         x86_64, linux-gnu
status
major          4
minor          4.0
year           2024
month          04
day            24
svn rev        86474
language       R
version.string R version 4.4.0 (2024-04-24)
nickname       Puppy Cup
The environment variables seem all correct:
_R_CHECK_COMPILATION_FLAGS_KNOWN_
                                  -Wformat -Werror=format-security
-Wdate-time
BROWSER /usr/lib/rstudio-server/bin/postback/rpostback-browser
CLICOLOR_FORCE                   1
DISPLAY                          :0
EDITOR                           vi
GIS_LOCK                         817
GISBASE                          /usr/lib/grass83
GISDBASE                         /home/avallet/grassdata
GISRC                            /home/avallet/.grassrc8
GIT_ASKPASS                      rpostback-askpass
GRASS_ADDON_BASE                 /home/avallet/.grass8/addons
GRASS_INSTALLATION               /usr/lib/grass83
GRASS_MESSAGE_FORMAT             text
GRASS_PAGER                      cat
GRASS_PYTHON                     python3
HOME                             /home/avallet
LANG                             fr_FR.UTF-8
LD_LIBRARY_PATH
/usr/lib/grass83/lib::/usr/lib/R/lib:/lib:/usr/lib/x86_64-linux-gnu:/usr/lib/jvm/default-java/lib/server
LN_S                             ln -s
LOCATION_NAME                    file36b3e68712934
LOGNAME                          avallet
MAKE                             make
MAPSET                           file36b3e656a1ed9
MPLENGINE                        tkAgg
PAGER                            /usr/bin/pager
PATH
/usr/lib/grass83/bin:/usr/lib/grass83/scripts:/home/avallet/.grass8/addons/bin:/home/avallet/.grass8/addons/scripts:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin:/usr/lib/rstudio-server/bin/quarto/bin:/usr/lib/rstudio-server/bin/postback
PYTHONPATH                       /usr/lib/grass83/etc/python
R_BROWSER                        xdg-open
R_BZIPCMD                        /bin/bzip2
R_CLI_HAS_HYPERLINK_IDE_HELP     true
R_CLI_HAS_HYPERLINK_IDE_RUN      true
R_CLI_HAS_HYPERLINK_IDE_VIGNETTE
                                  true
R_DOC_DIR                        /usr/share/R/doc
R_GZIPCMD                        /bin/gzip -n
R_HOME                           /usr/lib/R
R_INCLUDE_DIR                    /usr/share/R/include
R_LIBS_SITE
/usr/local/lib/R/site-library/:/usr/local/lib/R/site-library:/usr/lib/R/site-library:/usr/lib/R/library
R_LIBS_USER /home/avallet/R/x86_64-pc-linux-gnu-library/4.4
R_PAPERSIZE                      letter
R_PAPERSIZE_USER                 letter
R_PDFVIEWER                      /usr/bin/xdg-open
R_PLATFORM                       x86_64-pc-linux-gnu
R_PRINTCMD                       /usr/bin/lpr
R_RD4PDF                         times,inconsolata,hyper
R_SESSION_TMPDIR                 /tmp/Rtmp9qeL4f
R_SHARE_DIR                      /usr/share/R/share
R_STRIP_SHARED_LIB               strip --strip-unneeded
R_STRIP_STATIC_LIB               strip --strip-debug
R_TEXI2DVICMD                    /usr/bin/texi2dvi
R_UNZIPCMD                       /usr/bin/unzip
R_ZIPCMD                         /usr/bin/zip
RMARKDOWN_MATHJAX_PATH /usr/lib/rstudio-server/resources/mathjax-27
RS_PORT_TOKEN                    1be40ec3f539
RS_RPOSTBACK_PATH /usr/lib/rstudio-server/bin/rpostback
RS_SERVER_RPC_SOCKET_PATH
/var/run/rstudio-server/rstudio-rserver/session-server-rpc.socket
RS_SERVER_URL                    http://134.158.74.74:8080/
RS_SESSION_TMP_DIR /var/run/rstudio-server/rstudio-rsession
RS_SESSION_URL
RSTUDIO                          1
RSTUDIO_CLI_HYPERLINKS           true
RSTUDIO_CONSOLE_COLOR            256
RSTUDIO_CONSOLE_WIDTH            112
RSTUDIO_HTTP_REFERER             http://134.158.74.74:8080/
RSTUDIO_PANDOC /usr/lib/rstudio-server/bin/quarto/bin/tools/x86_64
RSTUDIO_PROGRAM_MODE             server
RSTUDIO_R_MODULE
RSTUDIO_R_PRELAUNCH_SCRIPT
RSTUDIO_R_REPO
RSTUDIO_R_VERSION_LABEL
RSTUDIO_SESSION_PID              224062
RSTUDIO_SESSION_STREAM           avallet-d
RSTUDIO_USER_IDENTITY            avallet
RSTUDIO_USER_IDENTITY_DISPLAY    avallet
SED                              /bin/sed
SSH_ASKPASS                      rpostback-askpass
TAR                              /bin/tar
TERM                             xterm-256color
USER                             avallet
Anyone knows what might be the problem?
Best regards,
Améline
Améline Vallet
Researcher at AgroParisTech
Laboratoire Ecologie, Systématique et Evolution - UMR 8079
Centre international de recherche sur l'environnement et le développement - UMR 8568
http://www.amelinevallet.com/ | @vallet_ameline
grass-stats mailing list
https://lists.osgeo.org/mailman/listinfo/grass-stats
More information about the grass-stats mailing list
