[GRASS translations] Marathi translation - was Re: [GRASSLIST:6967] Re: please lookup this bugreport
Markus Neteler neteler at itc.it
Mon Jun 20 23:09:39 EDT 2005
Hi Swapnil Hajare,
thanks for your submission. Now your Marathi fils are in 6.1-CVS.
I have slightly modified the file names to match the current
GRASS scheme.
On Mon, Jun 20, 2005 at 11:41:53PM +0530, janabhaaratii at ncst.ernet.in wrote:
> Markus Neteler wrote:
> > Let me propose the following: If you could translate a minimum
> > (a few messages) and send us the .po file, we can insert it into
> > GRASS and run some tests. Please indicate which locale/font packages
> > are needed.
> I have uploaded partially translated grass po files for Marathi (mr_IN) to
> http://www.janabhaaratii.org.in/portal/Members/swapnil/tmp/gis/
> locale: mr_IN
> encoding: UTF-8
> Font: http://www.janabhaaratii.org.in/janabhaaratii/src/fonts/Gargi_1.7.ttf
> I have done the translations for demonstration only. They are not final.
> Now will wait for your response.
Please test from CVS and continue...
Thanks!
 Markus
More information about the grass-translations mailing list
