[GRASS translations] New translator
Daniel Victoria daniel.victoria at gmail.com
Wed May 31 19:46:53 EDT 2006
Hi Eve,
So let me see if I got this straight. In order for 2 persons to work
on the translation we either work on separate files or check out the
files from CVS, translate some lines, and send it back, all in the
same "work shift"?
Also, I just downloaded from CVS and tried to follow the instructions
but for some reason the compiler is not working on my machine and I
can't issue the command make pot. So my question is, what if I just go
straight to the locale/po file and start working with the .po files in
there? Will that work?
Cheers
daniel
On 5/31/06, Eve Rousseau <eve.red at magic.fr> wrote:
> Good evening Daniel,
> > I talked to Paulo Marcondes (pmarc) about helping him out with the
> > Portuguese (Brazilian) translation of GRASS and we where wondering,
> > are there any tips/trick for two persons to work on the same language?
> > How do people coordinate such things?
> You can split work on files : one working on grasslibs, the other on grassmods
> (or maybe between type of messages : fuzzy translations/untranslated).
> The main constraint is time available - most often, translators don't work
> simultaneously (every other week/month/etc.) ... Therefore, the rule is always :
> 1) commit early
> 2) commit often
> Hope this
> helps.
>         Interface WebMail / Magic OnLine
>               http://www.magic.fr
More information about the grass-translations mailing list
