[GRASS translations] As a new member...
Carlos Dávila cdavilam at jemila.jazztel.es
Thu Aug 2 11:59:05 EDT 2007
Vincent BAIN escribió:
> Hello,
> the french translation team has a new member from now on. I began
> translating some messages in the grasstcl_fr section, and I already get
> squeezed...
> When I try to compile grass (last version from the cvs) with the option
> --with-nls, then the compilation looks clean ; the result of make is :
> No errors detected.
> But when I try to install the program (with make install) it fails, the
> error returned is :
> if [ 1 -eq 1 ] ; then cd /home/vincent/grass6/dist.i686-pc-linux-gnu ;
> tar cBf - locale | (cd /usr/local/grass-6.3.cvs ; tar xBf - )
> 2>/dev/null ; fi
> make[1]: *** [real-install] Erreur 2
> However when I configure grass without the nls option, the installation
> works fine.
> Could anyone help me figure out why it does not work ?
I have just compiled (with nls) and installed with the latest cvs and
had no problem. May be you have some error in your new grasstcl_fr.po
file. Try with a previous version. You can use kbabel or poedit tools to
check your file.
I hope this help
Regards
Carlos
More information about the grass-translations mailing list
