[GRASS translations] Viewing changes in po files
Glynn Clements
glynn at gclements.plus.com
Sun Jan 7 05:20:51 EST 2007
Carlos Dávila wrote:
> I'm collaborating in the translation of es.po files. I would like to
> confirm if it is necessary to compile grass from source enabling nls to
> incorporate translated files or if it is possible to manually do it into
> already installed grass (from package).
You can use a binary package, provided that it was built with NLS
enabled.
More information about the grass-translations
