[GRASS-translations] incorrect refs?
Maxim Dubinin
sim at gis-lab.info
Sat Aug 2 16:29:28 EDT 2008
I should've told where I took our po-files, checking out new svn (https://svn.osgeo.org/grass/grass/trunk) fixed
the references.
Thanks for your help!
Maxim mailto:sim at gis-lab.info
Вы писали 2 августа 2008 г., 14:17:08:
ML> Hi,
ML> 2008/8/2 Maxim Dubinin <sim at gis-lab.info>:
>> We took source *_ru.po files from here:
>> http://trac.osgeo.org/grass/browser/grass/trunk/locale/po
>> where it says somewhere that the file were updated with the current
>> code.
>> the code I used to link was taken from here
>> http://grass.osgeo.org/grass63/source/grass-6.3.0.tar.gz
ML> SVN trunk is not corresponding to grass-6.3.0.tar.gz, its grass7 code
ML> (still very similar to grass6 code-base, but it will change). If you
ML> used po file from trunk you should checkout svn trunk then, see
ML> http://trac.osgeo.org/grass/wiki/DownloadSource
ML> Martin
More information about the grass-translations
