[GRASS-translations] malayalam translation
Markus Neteler neteler at osgeo.org
Tue Feb 23 02:46:15 EST 2010
On Tue, Feb 23, 2010 at 8:29 AM, Mohammed Rashad <rashadkm at yahoo.com> wrote:
> I am working on new translation of grass meesages (Malaylam).
> I followed steps on translation wiki for starting new translation and
> created *.po files using `make pot`. my problem is after make install it
> shows this error
> Starting GRASS ...
> Traceback (most recent call last):
>   File "/usr/local/grass-6.4.0svn/etc/wxpython/gis_set.py", line 850, in
> <module>
>     import gui_modules.gcmd as gcmd
>   File "/usr/local/grass-6.4.0svn/etc/wxpython/gui_modules/gcmd.py", line
> 53, in <module>
>     from grass.script import core as grass
>   File "/usr/local/grass-6.4.0svn/etc/python/grass/script/__init__.py", line
> 1, in <module>
>     from core   import *
>   File "/usr/local/grass-6.4.0svn/etc/python/grass/script/core.py", line 34,
> in <module>
>     gettext.install('grassmods', os.path.join(os.getenv("GISBASE"),
> 'locale'), unicode=True)
>   File "/usr/lib/python2.5/gettext.py", line 493, in install
>     t = translation(domain, localedir, fallback=True, codeset=codeset)
>   File "/usr/lib/python2.5/gettext.py", line 478, in translation
>     t = _translations.setdefault(key, class_(open(mofile, 'rb')))
>   File "/usr/lib/python2.5/gettext.py", line 180, in __init__
>     self._parse(fp)
>   File "/usr/lib/python2.5/gettext.py", line 337, in _parse
>     tmsg = unicode(tmsg, self._charset)
> LookupError: unknown encoding: CHARSET
You have to fill out the header of these files (see other languages in
locale/po/ )
Markus
> Error in GUI startup. If necessary, please
> report this error to the GRASS developers.
> Switching to text mode now.
> Hit RETURN to continue...
> any help will be greatly appreciated..
> Thanks & Regardds
> Mohammed Rashad K.M
> http://keralainfo.web4all.in
> grass-translations mailing list
> grass-translations at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-translations
More information about the grass-translations mailing list
