[GRASS-translations] Questions
Monica Buescu monicabuescu1985 at gmail.com
Mon May 16 20:49:41 EDT 2011
Hi Markus
One solution was to add a label to Quit and Exit button in gis_set.py
(suggestion from Antonio Rocha). It has worked
> > - Meridian Parallel and other similar parameters used to define
> Location's
> > geographic parameters (none of those are there) (in Locations Wizard)
> please indicate the phrases, maybe they were not yet tagged for
> translation?
> Expressions (depends on the projections):
Central Parallel
Central Meridian
Supress Skew
South Hemisphere
Yes
No
(among others)
How to get there? (enter Location Wizard> Select Coordinate System from  a
list >(select a coordinate system)
> > - Next and Back button used in Locations Wizard
> Same as Quit and Help button...
> Hope this helps
> Markus
URL: http://lists.osgeo.org/pipermail/grass-translations/attachments/20110517/7fa92f91/attachment.html
More information about the grass-translations mailing list
