[GRASS-translations] Spanish translation
Enrique Cerrillo Cuenca
enrique.cerrillocuenca at gmail.com
Sun Dec 7 18:42:17 PST 2014
“Location” does not mean “localidad” (municipality, village) in Spanish. I think that although “localización” might sound weird in Spanish, is the right term. “Localización” means “action and effect of locating” (Royal Academy of Spanish language: Acción y efecto de localizar).
Please be careful about what you translate, Spanish users can be really confused if you change basic terms like this one. Maybe you should have addressed your question to the Spanish list of GRASS (http://lists.osgeo.org/listinfo/grass-es <http://lists.osgeo.org/listinfo/grass-es>).
Some years ago there was a person who managed the Spanish translations of GRASS, but I don’t know who is in charge right now.
Enrique
> El 8/12/2014, a las 3:07, Daniel Torres <nobeeakon at gmail.com> escribió:
> Hi, I'm doing the spanish translation of GRASS 7, and found on the glossary (http://grasswiki.osgeo.org/wiki/GRASS_Translation_Glossary <http://grasswiki.osgeo.org/wiki/GRASS_Translation_Glossary>) that the translation of "location" is "localización", that, as far as I understand is not a very adequate translation, I think that "localidad" would be a better and more intuitive translation. ¿Any suggestion or abjection to this?
> Buenas, estoy empezando a hacer la traducción al español de GRASS 7, encontré que en el glosario (http://grasswiki.osgeo.org/wiki/GRASS_Translation_Glossary <http://grasswiki.osgeo.org/wiki/GRASS_Translation_Glossary>) la traducción para "location" es "localización", sin embargo esa palabra es, a mi parecer, inadecuada, creo debería ser sustituida por localidad, que es una traducción más adecuada y da una mejor idea del concepto de location. ¿Alguien con alguna objeción o propuesta? si esto es aceptado, ¿cómo cambiar lo que está en el glosario?
> PD. After translating a piece to whom I send the modified file?
> Saludos,
> Daniel
> 2014-12-06 21:59 GMT-06:00 Abdoul Dia <dia.abdoul at gmail.com <mailto:dia.abdoul at gmail.com>>:
> Hi Daniel,
> You could start from here: http://grass.osgeo.org/development/translations/ <http://grass.osgeo.org/development/translations/>
> Cheers
> Abdoul
> On 14-12-06 10:56 PM, Daniel Torres wrote:
>> Hi, I'm from México, obviously I want to help in spanish translation, however don't fully understand the way to do it, could any one explains me the translation dynamics? And... after I translate a part, what do I need to do?
>> Cheers,
>> Daniel
>> grass-translations mailing list
>> grass-translations at lists.osgeo.org <mailto:grass-translations at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/grass-translations <http://lists.osgeo.org/mailman/listinfo/grass-translations>
URL: <http://lists.osgeo.org/pipermail/grass-translations/attachments/20141208/a5f55ca7/attachment-0001.html>
More information about the grass-translations
