[GRASS-translations] Fwd: [OSGeo-Discuss] Help us test out Weblate
Huidae Cho grass4u at gmail.com
Wed Feb 16 14:03:55 PST 2022
Markus,
Weblate looks promising. Can we *try* it?
Best,
Huidae
On Fri, Jan 7, 2022 at 5:00 AM Markus Neteler <neteler at osgeo.org> wrote:
> Dear translators,
> For the time being our translations have been managed via
> https://www.transifex.com/grass-gis/
> FYI, OSGeo is now hosting an open source solution for message translations:
> https://weblate.osgeo.org/
> Just in case one day we want to migrate :-)
> See also below.
> Best,
> Markus
> ---------- Forwarded message ---------
> From: Regina Obe via Discuss <discuss at lists.osgeo.org>
> Date: Fri, Jan 7, 2022 at 12:47 AM
> Subject: [OSGeo-Discuss] Help us test out Weblate
> To: <discuss at lists.osgeo.org>
> Cc: PostGIS Users Discussion <postgis-users at lists.osgeo.org>,
> pgRouting developers mailing list <pgrouting-dev at lists.osgeo.org>
> We have Weblate installed on OSGeo infra
> At
> For a trial run I'm using our PostGIS workshop
> You can login with your LDAP credentials and then I can grant you rights to
> the postgis-workshop project.
> If I set this up right - commits should show up after an hour or so after
> each commit on the below links.
> English: https://postgis.net/workshops/en/postgis-intro/
> Japanese:  https://postgis.net/workshops/ja/postgis-intro/
> German: https://postgis.net/workshops/de/postgis-intro/
> Spanish: https://postgis.net/workshops/es/postgis-intro/
> Italian: https://postgis.net/workshops/it/postgis-intro/
> And you should see your commit show here:
> https://github.com/postgis/postgis-workshops
> here is an example Sandro did -
> https://github.com/postgis/postgis-workshops/commit/f3b1f810a9c25d2889c2216b
> 62d4843a44544858
> <https://github.com/postgis/postgis-workshops/commit/f3b1f810a9c25d2889c2216b62d4843a44544858>
> My plan is after we are done with some kicking of tires, we will switch
> PostGIS docs from transifex to weblate.
> For others who want to try it on their projects, let me know I can show you
> what little I know about the topic :)
> Thanks,
> Regina
> Discuss mailing list
> Discuss at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/discuss
> grass-translations mailing list
> grass-translations at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-translations
Huidae Cho, Ph.D., GISP, /hidɛ <http://ipa-reader.xyz/?text=hid%C9%9B>
t͡ɕo/, 조희대, 曺喜大
GRASS GIS Developer
https://idea.isnew.info/
URL: <http://lists.osgeo.org/pipermail/grass-translations/attachments/20220216/79805284/attachment.html>
More information about the grass-translations mailing list
