[GRASS-translations] Fwd: [OSGeo-Discuss] Help us test out Weblate
Markus Neteler
neteler at osgeo.org
Wed Feb 16 23:40:11 PST 2022
Hi Regina,
The GRASS GIS project would be interested to try out Weblate.
What needs to be done for this?
Thanks,
Markus
On Wed, Feb 16, 2022 at 11:04 PM Huidae Cho <grass4u at gmail.com> wrote:
> Markus,
> Weblate looks promising. Can we *try* it?
> Best,
> Huidae
> Huidae Cho, Ph.D., GISP, /hidɛ t͡ɕo/, 조희대, 曺喜大
> GRASS GIS Developer
> https://idea.isnew.info/
> On Fri, Jan 7, 2022 at 5:00 AM Markus Neteler <neteler at osgeo.org> wrote:
>> Dear translators,
>> For the time being our translations have been managed via
>> https://www.transifex.com/grass-gis/
>> FYI, OSGeo is now hosting an open source solution for message translations:
>> https://weblate.osgeo.org/
>> Just in case one day we want to migrate :-)
>> See also below.
>> Best,
>> Markus
>> ---------- Forwarded message ---------
>> From: Regina Obe via Discuss <discuss at lists.osgeo.org>
>> Date: Fri, Jan 7, 2022 at 12:47 AM
>> Subject: [OSGeo-Discuss] Help us test out Weblate
>> To: <discuss at lists.osgeo.org>
>> Cc: PostGIS Users Discussion <postgis-users at lists.osgeo.org>,
>> pgRouting developers mailing list <pgrouting-dev at lists.osgeo.org>
>> We have Weblate installed on OSGeo infra
>> At
>> For a trial run I'm using our PostGIS workshop
>> You can login with your LDAP credentials and then I can grant you rights to
>> the postgis-workshop project.
>> If I set this up right - commits should show up after an hour or so after
>> each commit on the below links.
>> English: https://postgis.net/workshops/en/postgis-intro/
>> Japanese: https://postgis.net/workshops/ja/postgis-intro/
>> German: https://postgis.net/workshops/de/postgis-intro/
>> Spanish: https://postgis.net/workshops/es/postgis-intro/
>> Italian: https://postgis.net/workshops/it/postgis-intro/
>> And you should see your commit show here:
>> https://github.com/postgis/postgis-workshops
>> here is an example Sandro did -
>> https://github.com/postgis/postgis-workshops/commit/f3b1f810a9c25d2889c2216b
>> 62d4843a44544858
>> My plan is after we are done with some kicking of tires, we will switch
>> PostGIS docs from transifex to weblate.
>> For others who want to try it on their projects, let me know I can show you
>> what little I know about the topic :)
>> Thanks,
>> Regina
>> Discuss mailing list
>> Discuss at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/discuss
>> grass-translations mailing list
>> grass-translations at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-translations
More information about the grass-translations
