[GRASS-translations] Fwd: Fwd: [OSGeo-Discuss] Help us test out Weblate
Markus Neteler
neteler at osgeo.org
Thu Feb 17 13:22:12 PST 2022
(FWD to the list as Regina isn't subscribed)
---------- Forwarded message ---------
Date: Thu, Feb 17, 2022 at 7:38 PM
Subject: RE: [GRASS-translations] Fwd: [OSGeo-Discuss] Help us test out Weblate
To: Markus Neteler <neteler at osgeo.org>
Cc: GRASS translations <grass-translations at lists.osgeo.org>, Huidae
Cho <grass4u at gmail.com>
Markus,
Can you log into weblate.osgeo.org with your OSGeo account.
Once you log in I can give you Admin rights and then you can setup any
projects you need.
For github integration if you want to use the pull request model, you
will need to setup the project as Github instead of git.
Pull requests will come from osgeoweblate github account.
Here is an example of what one looks like:
https://github.com/postgis/postgis-workshops/pull/41
If you need help pulling over the files let me know.
The tricky part is you have to setup Component Discovery to have the
files pull over and continue to update.
Thanks,
Regina
More information about the grass-translations
